| View Poll Results: Do you think it's best to pick up balls from both sides? | |||
| Yes |
66 | 42.58% |
| No |
89 | 57.42% |
| Voters: 155. You may not vote on this poll | |||
Picking up from both sides
A subject came up at our meeting today about making it so we have the ability to pick up balls from both sides. It would require no extra pulleys, etc., however would leave the entire middle part of our robot open, relying on other currently unknown ways to strengthen the frame.
I' can go either way, but I want to see CD's opinion on this subject. What are your thoughts on how to do it, and why? EDIT: Would it be legal in the bumper rules if both sides of a wide-based robot were open for pick-up? Thanks! Last edited by Andrew Lawrence : 18-01-2012 at 23:12. |
Re: Picking up from both sides
we were wondering the same thing.
live long and prosper reply to us when u find out so we can destroy you. lololololol ![]() |
We thought of this but we decided against it because we though it would require some sort of hopper. We didn't think that was a necessity this year with the three ball rule.
Sounds great for an increased pickup area but would require a lot of extra work and when your drive can pull a quick 180!
If you have a 2006 Behind the Design, someone did do that. I don't remember who, though.
In this game, I think you're not going to want to. Even if we could pick up an unlimited number of balls, it'd still be better to only have one gatherer. Not only is it easier to build and maintain, it'd be easier for most to control. MOST (there are exceptions to everything) drivers have it easier maintaining ONE frame of reference, as in "I pick up from the front." The time it takes to switch orientation from driving forwards to back probably isn't that much faster than pulling a U-ey in an agile robot, so I'd say focus your efforts elsewhere. That being said, if your team's hearts are set on it, go for it! Let us know how it turns out! |
#7
Last year, for example, we could do a full field run to the HP station "backwards", then invert and do the whole run "forwards" to score. If driven correctly, our "back" was almost always to the opposing team, we always backed through stuff and came at it head on, since it was just faster to do it that way. Way back in 2006, we collected from one side and shot out the other. Even further back in 2001, we had a totally invertable (front/back) robot with a claw on both sides that could work either way. Last edited by apalrd : 19-01-2012 at 22:36. Reason: messed up the quote tag |
#8
I personally don't think it is worth the trouble. It would most likely raise you center of gravity too. Since there is a limit of three balls I don't see a HUGE advantage.
#9
Thanks everyone for your replies! I'll show my team the results of this.
#10
Our team has come up with some designs for this exact method and also some strategies to implement it. If you are creating a bot that is not super agile this is a great method, no need to turn, keep the turret lined up on the net, don't always have to rely on the targeting program to aim 100% correctly. With this design you will have to shoot balls more frequently since you can only hold 3 at a time and it is a great way to clear all of the REBOUNDS from your opponents goal. Think about it, line up your robot so it collects parallel to the fender on your opponents side and launch all of the balls over to your side for a "dunker" robot to put them in real quickly.
Every design idea has a good strategy you can implement with it. It just has to be the strategy your team wants to do. Claimer: This was an idea that was brainstormed and prototyped. This design will not necessarily end up on the final designs for team 2851 Crevolution. |
#12
I added to the question (didn't want to make a whole new thread). What are your thoughts on that?
Thanks all! I really appreciate it! |
#13
Our team has been thinking about (and CADing) picking up from both sides, because we want to be able to rush backwards at the beginning of autonomous and grab balls from the coopertition ramp( after firing our initial two preloads). Of course, it all depends on what kind of shooter we build and were we put it on the robot, but we are open to the possibility that we might need to pick up from both sides.
#14
If you had a robot that loaded from the front, you could position it in the key with the front of the frame (with ball pickup) facing the ramp. Shoot your balls with the shooter pointing behind you, drive forward to the ramp, and get the ramp balls.
#15
The bumper rules say nothing about the number of openings, so it is very possibly to do this legally.
As for the strategic value, we considered it, but determined that the added complexity in having a second intake and somehow joining them was not worth the saved time of turning the robot 180º. However, this does mean that we are going to be careful and deliberate about which side we put our one intake on (behind or in front of - or even to the side of - our scoring mechanism). |
