Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 19-01-2012, 14:35
frankthelyon frankthelyon is offline
FRC #2557
frankthelyon is an unknown quantity at this point
Labview error 7
Hello, a couple days ago my team was installing Labview FRC 2012 on all of our machines, and we have encountered a problem. Labview installed correctly on only 2 computers. The other two get "error #7" whenever we try to create a cRio robot project. If we open a project, we get a rt compactrio target error. I have reinstalled and repaired installations countless times, and I am even trying it on different computers to no avail. Any help would be greatly appreciated.
Unread 19-01-2012, 16:50
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Labview error 7
Error 7 is a file permissions error. "File not found" or access denied. I assume that you are installing from the USB key found in the KOP. Try copying the contents of the installer to your hard drive first, then reattempt the install.
Good luck.
Mike B
Unread 19-01-2012, 19:48
FRC #2557
Re: Labview error 7
I re-installed everything using your advice, and I still received an "error 7". Thank you for the help.
Unread 20-01-2012, 00:00
Re: Labview error 7
Make sure the LabVIEW Data directory is in the current user's Documents folder.
We got errors like that when trying to move a robot project from one computer to another where the user names did not match. There's a lot of folder name configuration in a LabVIEW project that needs to be redone if you're moving a project around.
Unread 20-01-2012, 14:02
FRC #2557
Re: Labview error 7
I checked my folder locations, and I am still getting error 7. Thank you for the help.
Unread 20-01-2012, 21:51
Re: Labview error 7
Is there enough space on those computers' hard disks?
Unread 21-01-2012, 01:32
FRC #2557
Re: Labview error 7
There is most definitely enough room. (100+gb).
Unread 21-01-2012, 10:00
SuperS_5's Avatar
FRC #1219
Re: Labview error 7
When you create the project, have you tried different locations, or just the defaults? Can you try to save the project to somewhere like a USB stick?
Mike B
Unread 21-01-2012, 15:09
FRC #2557
Re: Labview error 7
I tried creating a project on a usb drive, and still got error 7. I will go to the shop today and do a complete reinstall.
Unread 21-01-2012, 16:41
FRC #2557
Re: Labview error 7
YAY!!! I fixed it! Full reinstall using original labview disk. Thank you for all of the help.
