Go to Post To my surprise, purple painted air tanks were illegal last year. AB - Andy Baker [more]
Unread 19-01-2012, 18:38
Citrus Citrus is offline
FRC #1678
Citrus is an unknown quantity at this point
Calculating distance with an Axis Camera 206
My team is using an axis camera to calculate the distance to a target. The distances we are currently calculating are up to a foot off, depending on the location, lighting etc. The calculated distances are worse at angles. What accuracy range are other teams getting? Do you think the camera is the best way to get the distance? We have also done tests with the ultrasonic sensor which is sometimes very accurate and other times gives strange results.
Thank you.
Unread 19-01-2012, 19:57
Re: Calculating distance with an Axis Camera 206
How are you calculating the distance using the camera?
Greg McKaskle
Unread 19-01-2012, 23:12
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
I second this question. If you can't get better estimates from the axis camera, you might try using the camera as a sanity check for an ultrasonic sensor.
Unread 20-01-2012, 07:01
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
With any vision system, you could fill in the area of the "square" target that is found with the "edge detection". This way you get a solid square.
Once you have a soild square, now run an "area detection" of the square.
This will get you a size. The bigger the area, the closer you are. The smaller the area, the further away you are.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 20-01-2012, 10:43
A smaller area could also mean you are just farther away from the line perpendicular to the target, even if you are the same distance from the target itself.
Citrus, what algorithm are you using to compute distance?
Unread 20-01-2012, 13:10
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Would it be more accurate to use the ratio of size of the rectangle in comparison to the overall picture (ie. The smaller the rectangle in pixels, the farther away you are moving from it) and then using the length and width of the sides to calculate for angle?
And I'm one of those NEMs (Non-engineering Mentors) so the math escapes me completely here.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 20-01-2012, 14:08
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Can someone please post the documentation for detecting the squares and tracking them? I can't seem to find the PDF's or tutorials.
Thanks,
Eagle Engineering 1138
Unread 20-01-2012, 17:16
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Basically, yes. Involves a fair amount of trig, but this is how I am doing it, and it works well.
Unread 21-01-2012, 02:17
FRC #1678
We are using the height of the target and comparing it to the height of the camera image.
Unread 30-01-2012, 17:14
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Correct me if im wrong, but cant you use a exponential regression for the correlation from height of rectangle to distance away (at least it seems a exponential regression is the right way to go)
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 31-01-2012, 16:43
ganchara ganchara is offline
FRC #2523 (Hilltoppers)
ganchara is an unknown quantity at this point
Does OpenCV have a program that will spit out code for you similar to what the NI Vision Assistant program does? It seems like using OpenCV will be easier for my team to implement our rectangle tracking with if it does, as we are having some trouble understanding the code that is spit out by Vision Assistant.
Unread 31-01-2012, 20:59
caseydech caseydech is offline
None #1391
caseydech is an unknown quantity at this point
my team uses the axis camera to identify blobs (yes its the technical term for the... blobs that the camera picks up) And then finds the distance based on the pixel distance between top square and bottom square, angle uses trig and distance from side targets, labview can calculate the rest
Unread 31-01-2012, 21:21
Derschatten Derschatten is offline
FRC #1203 (Pandemonium)
Derschatten is an unknown quantity at this point
I have seen a lot of people over look this in past year. Make sure you are converting it to foot and inches or whatever you desire as 1' would be 1.2 as a double.
Unread 01-02-2012, 01:35
FRC #1700
Sure you can, but you need to get a baseline to start from, which can be found by going through the trig for one image, or going to a field and finding it through measurements there.
Yeah, this is what I hope to do, since the error is much less than using a single target. But, if one target is not found, you will need to do the math without it, which makes things very interesting (and a whole lot of if-else, unless I find a more elegant way to do it)
Unread 20-01-2012, 14:48
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
There are numerous algorithms... we are trying opencv with relatively little success.
Anyone else have better experiences with opencv?
