Go to Post I applaud teams that make signs of all kinds - giant numbers, large banners, humongous heads. It's all good. - Ryan Dognaux [more]
Unread 20-01-2012, 09:10
jeleser's Avatar
jeleser jeleser is offline
AKA: Justin Eleser
FRC #2080 (Torbotics)
jeleser is just really nicejeleser is just really nicejeleser is just really nicejeleser is just really nice
Windows Activation Error
We've re-imaged our classmate and are now trying to activate Windows. There's a secure internet connection, and when we try activating it we get this error message:
Error 0xC004F074
Description: The Software Licensing Service reported that the computer could not be activated. No Key Management Service (KMS) could be contacted. Please see the Application Event Log for additional information.
Have any other teams been getting this error? If so, have you found a fix? I've been searching the FIRST website and posts on here, but what I've found pertains to last year. I'm a bit cautious of applying an old fix. I remember having this problem last year as well, but my mind goes blank as to how we solved it.
Team 2080 Torbotics
2010- General build, Pit scouting
2011-2012- Electronics/Programming, Driver
2013- Electronics/Programming, Drive Coach
Unread 20-01-2012, 09:18
Re: Windows Activation Error
This thread on the FIRST forums might help: http://forums.usfirst.org/showthread.php?t=18490
Unread 20-01-2012, 11:33
After we used the E09 reimaging flash drive, our E09 Classmate was successfully activated (at a mentor's home, because we do not have internet access at our workshop). A week later, after using files copied from a local rookie team, we reimaged our E11 Classmate. Using the same internet connection as before, Windows fails to activate, showing an error different from the one in this thread. It's the error reported by SMHS in post #6 of the referenced thread.
I reimaged the Classmate several times. I was never able to get the "Use the automated phone system" option to appear, using any of the available login accounts. I'll be working on it again this weekend.
Unread 21-01-2012, 13:07
jeleser's Avatar
AKA: Justin Eleser
I ended up going to the 2011 KOP website, and applied the fix from there. It worked fine, and as far as I know it shouldn't cause any problems.
Team 2080 Torbotics
