Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 20-01-2012, 19:46
pureFloat pureFloat is offline
AKA: Moby
FRC #3506 (Yeti)
pureFloat is an unknown quantity at this point
Can someone explain BinaryImage?
I've been looking at a lot of threads having to do with tracking the hoops, and most of them involve converting the camera's image to a BinaryImage type. What exactly is this? Does it make all bright colors trues and all dark colors false? Also, can someone please explain what a ParticleAnalysisReport object does? That seems to be what the majority of the methods for BinaryImage return. I've read through this, but I can't understand everything for the above reasons.
Thank you for any help!
Unread 20-01-2012, 20:33
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Can someone explain BinaryImage?
A binary image is the result of an image filter applied to one of many types.
Just like a regular image represents a large array of pixels representing the colors seen by the camera, a binary image is also an array of pixels; however, for the binary image, instead of color, each pixel holds only a single true/false value.
For example, lets say you had a picture, and you ran a filter on it that returned true for all pixels that had a blue value of >150, and false for everything else. The binary image that would be produced would have each pixel be false for those with blue content of less than 150, and vice versa for the others.
The ParticleAnalysisReport object represents the results of an analysis of particles. For binary images, particle analysis involves finding groups of "true" pixels close together, and treating them as observed particles. The methods operating on binary images let you find and analyze particles to your liking.
For this years game, the particle analysis report could provide information on where blackboards, the possibly largest particles found due to the retroreflective tape, if the filter providing the binary image is tuned, are.
Attending: MN Duluth Regional
Unread 21-01-2012, 01:31
AKA: Moby
FRC #3506 (Yeti)
Thank you so much. That cleared things up a lot and I understand the basics of it now. Do you know of anywhere I could go to see an example of this? I couldn't find sample code in Netbeans.
Unread 21-01-2012, 01:35
JewishDan18's Avatar
JewishDan18 JewishDan18 is offline
FRC #1700
JewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to beholdJewishDan18 is a splendid one to behold
Sample code just for Labview, I believe. There is an example for last year that will show you, but I do not know where it is.
Unread 21-01-2012, 09:19
AKA: Moby
FRC #3506 (Yeti)
There is sample code in Java. When you open a new project, you can go to Samples>FRC Java, and it has several sample programs, including things like tank drive with the Kinect. However, the closest I could find to tracking the hoops was a sample Lunacy tracker.
Unread 21-01-2012, 15:52
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Look for the camera test project under samples.
Brad
Brad Miller
Robotics Resource Center
Unread 21-01-2012, 06:25
AKA: Brad
I'm posting an update later today that includes additional vision operations in Java along with a sample program, and sample images that demonstrates finding 2012 targets. You can use it as a starting point.
Brad
Brad Miller
Unread 21-01-2012, 09:16
AKA: Moby
FRC #3506 (Yeti)
Thanks, I'll be sure to read it as soon as you put it up.
