Go to Post Trust your data! - eugenebrooks [more]
Unread 21-01-2012, 12:08
aya94 aya94 is offline
aya94 is an unknown quantity at this point
Kinect configuration
When configuring the kinect we should download a file (steps in getting started PDF page 43), should I download the "32-bit download" on my classmate or on the pc I am using for developing (I am using different computer for developing than the classmate )??
Unread 21-01-2012, 12:11
Re: Kinect configuration
You need to install the Kinect SDK and Kinect Server on the computer you will plug the Kinect into which should be your DriverStation computer (sounds like this is the Classmate). You do not need those programs on a computer where you are only writing C++ code for the robot.
Does that answer the question?
Unread 21-01-2012, 17:02
Yes thank u that helped ,and sounds logical too...thank u
