Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 22-01-2012, 13:01
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
Creating a Custom Dashboard for the Driver Station
In past years I have been using LabVIEW for my FRC programming, but this year since I'm taking the offered Computer Science A course at my school I decided it would be cool to try my hand at Java. So far, everything is going well. Though one of the problems I'm running into is trying to figure out how to make the dashboard, I'm thinking it's a basic GUI interface...that I haven't learned how to make yet.
are there any helpful websites, tutorials and such to help me make a dashboard? Or examples of code and implementation. I've "googled" and haven't had much luck.
John Fogarty
Unread 22-01-2012, 13:41
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Creating a Custom Dashboard for the Driver Station
I'd suggest looking into SmarDashboard, this should get you in the right direction with minimal learning curve. It's a modular dashboard which replaces the stock one. It makes it pretty easy to add custom stuff to the UI, but the documentation is lacking. I'm still new to it, but this is what I did to get it working:
Smart Dashboard Guide
Edit: I'm actively working on this guide, so check back for more info soon!
http://team2168.org
Unread 22-01-2012, 15:09
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
I'm also creating some dashboard software with python.. It'll be much easier to program for than java (no eclipse/netbeans, no crap. just a text editor and a console)
SmartDashboard's documentation really turned me off, and since I'm creating some server/client stuff for onboard netbook anyway.. might as well extend that.
Unread 23-01-2012, 20:29
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
You may also want to look into ZomB: http://www.chiefdelphi.com/forums/sh...ad.php?t=82612
Unread 26-01-2012, 09:02
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Another option is to use the RCP application building part of Eclipse (of which the IDE is just an example) to build a custom dashboard. There are several books with good tutorials for how to do this. You get access to all the GUI features that the IDE presents ... but instead of an IDE, you are building an FRC robot dashboard. Although this probably isn't a good option for rookie programmers in this build season.
Unread 26-01-2012, 13:13
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Our team planning to use swing for our dashboard.
Unread 27-01-2012, 13:27
AKA: Brad
#0190 ( Gompei and the Herd)
Check out the SmartDashboard video at http://youtube.com/user/bradamiller. It explains how to use the SmartDashboard and we'll add some more stuff about PID tuning next week.
Brad
Brad Miller
Robotics Resource Center
Unread 26-01-2012, 14:44
We're doing a web interface written with probably jQuery or closure tools
Unread 26-01-2012, 23:23
otherguy's Avatar
sparkE
AKA: James
Do you have any other info on what you're doing w/ jQuery? I'm interested in seeing your results. You guys should make a writeup if you get a chance.
http://team2168.org
Unread 28-01-2012, 18:10
Here's my dashboard:
Code again is here: https://github.com/FRCTeam4069/Mediator
Unread 26-01-2012, 23:47
I have a setup where it allows me to do that. Will do once i get my exam done
