Go to Post I would be kinda creeped out if I was one of the "famous" FIRST people. Why? Because no one is any different than anyone else in my eyes. Granted, some people stand out more, but that is because the other people might not have gotten a chance yet to shine. - Melissa Nute [more]
Unread 22-01-2012, 13:35
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Unhappy Camera not showing up in dashboard when connected to Crio
Hi!
I hope this is not a re-post. I looked at some other posts and they did not help.
So... I set up the camera as the getting started with the frc 2012 control system .pdf said. When I plugged the camera into the radio and opened the driver's station the camera would show up. However when I plug it into the 2nd Crio port it shows nothing even if I change the ip back to 192.168.0.90 I want to do vision processing so I need it to work plugged into the crio. ( I am using a crossover cable) Any advice? I can't even connect it to my computer anymore.
Thanks in advance.
Unread 22-01-2012, 13:56
Re: Camera not showing up in dashboard when connected to Crio
You can do image processing anywhere with it plugged into the DLink as you had it before. There is no particular reason to be plugging it directly into the cRIO.
The cRIO can request images from the camera just like the Driver Station does. The images come in via Ethernet either way.
If you really, really want to plug the camera into the cRIO port 2 for some strange reason, then the Driver Station must be changed to ask for images from the cRIO, and the cRIO code must be changed to forward images to the Driver Station. That'll slow the image stream down though. It's much more efficient to have the camera out on the general network and let both the Driver Station and cRIO request images from it there.
Unread 22-01-2012, 14:52
FRC #3476
Talking Re: Camera not showing up in dashboard when connected to Crio
Ok thank you very much!
Unread 26-01-2012, 16:54
Thomas Clark Thomas Clark is offline
Hacker
FRC #0237
Thomas Clark is infamous around these parts
How would you do this? I think the cRIO is broadcasting the images because a PCVideoServer is started, but I can't figure out how to get the driver station to show the processed images instead of the video directly from the camera. We have the new cRIO with only one ethernet port, so I can't plug the camera in there.
