Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 22-01-2012, 19:54
mlantry mlantry is offline
I'm back
AKA: Matthew Lantry
mlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud ofmlantry has much to be proud of
can someone help me with banebot motors?
for the gearboxes what is the difference in gear ratios like 4:1, 16:1, 64:1, 256:1.
Andrew Lawrence
Posts: n/a
Re: can someone help me with banebot motors?
Difference in speed and torque.
Unread 22-01-2012, 19:57
I'm back
AKA: Matthew Lantry
should have been more specific. from 4:!- 256:1 is there more torque with the higher ratio or more speed
Unread 22-01-2012, 20:00
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
4:1 the motor turns 4 times for one turn of the output shaft. So the output shaft spins 1/4 as fast as the motor, and has 4 times as much torque.
The higher the reduction, the slower the output shaft turns, and the more torque it has.
Unread 22-01-2012, 20:02
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Specifically, for example, the BaneBot M7-RS775-12 has a free speed (rpm) of 19300. When mated with a 4:1 gear box, it will slow the rpm to 4825 however, you gain torque when you give up the initial input speed.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
Unread 22-01-2012, 20:06
I'm back
AKA: Matthew Lantry
thank you
