Go to Post Just think of the deadline as your six week deadline for FIRST, just when you think you can't do it, you are amazed by what you can do. - JackN [more]
Unread 22-01-2012, 19:58
JChavis's Avatar
JChavis JChavis is offline
Team 3490's "Pro./Electrician"
FRC #3490 (Vyper Drive)
JChavis is an unknown quantity at this point
Question Kinect Boolean Programming
I've been working on the programming for our Hybrid/Autonomous mode and I have one important problem to solve...
At the competitions alliance teams must "choose" which member of the alliance will use the Kinect during the Hybrid Period. If you are the team to be selected, you would place the USB at the operating console into your laptop to activate the Field Kinect from the Kinect Station.
So here's my question:
How would you be able to detect in Labview (and Java) if the USB for the field Kinect is in the laptop or not. I believe it is similar to the Boolean involved in detecting if a button on a controller is pushed or not, but its not in my certainty to guess....
Hmmm....I wonder if I can create a robot lawnmower with the knowledge I have gained from FRC.....
Unread 22-01-2012, 20:01
Re: Kinect Boolean Programming
There are a number of options to do that using the data that will come in if you do have the Kinect plugged in and it's sending data to your robot. The easiest is probably to query the Number of Players and do Kinect stuff if it's 1 and non-Kinect stuff if it's zero. You should also decide what to do in the case that it's greater than 1 even though this shouldn't occur during competition.
The code to do this is obviously very different in the two languages, but I believe the Gesture Processing samples (unfortunately I don't have them on this PC to check) for both languages show how you would do this if you need help.
Unread 22-01-2012, 20:19
JChavis's Avatar
Thanks for the info, but is there a specific block in Labview to use? (i.e: JOYSTICK Open, DRIVE 4-Motors, GYRO Close)
Unread 22-01-2012, 20:23
Unfortunately I don't remember which block the number of players comes from in LabVIEW, it's definitely one from the Kinect palette. I think it's the Kinect Header, but Kinect Extra may also be a possibility.
Unread 22-01-2012, 22:14
MotorHead's Avatar
MotorHead MotorHead is offline
Programming Mentor
AKA: Jeff Beltramo
FRC #1922 (OZ-Ram)
MotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to beholdMotorHead is a splendid one to behold
I think this thread addresses one way to do what you want:
http://www.chiefdelphi.com/forums/sh...d.php?t=100643
Jeff Beltramo
Team #1922
Concord, New Hampshire
Unread 23-01-2012, 19:43
JChavis's Avatar
Thanks, Jeff, I'll see if I can Figure it out.
Unread 24-01-2012, 07:05
JChavis's Avatar
Lightbulb Re: Kinect Boolean Programming
Well, guys, I do believe that I have figured out a few ways to program this section in Autonomous/Hybrid. I am extreemely sure that these are some ways to go around this...
In the first picture, I didn't write a program in the false case block for the first scenario, I just entered some other programming options...
What do you guys think?
Name:	Hybrid Detect Samples.png
ID:	11548  Click image for larger version
Name:	Steps to Kinect Header Block.png
Unread 24-01-2012, 21:54
JChavis's Avatar
Exclamation Re: Kinect Boolean Programming
I have my examples for the kinect detection options, and I just need some quick feedback on it...
Unread 19-02-2012, 11:07
JChavis's Avatar
We are within 2 days before we have to stop testing the main robot...
Are the Examples I have given you a good way to tell the Autonomous/Hybrid program which program should run?
Unread 19-02-2012, 11:18
I would get rid of the two small case structures inside. Just put your non-Kinect auto code there. If there are 0 players, either the Kinect isn't being used or your player is not detected, either way you want to just run auto. If there are two players, you are not necessarily going to get good data from the Kinect so I would just run the auto code there as well. This means that if "players" is anything but 1, you want to run your auto code, which is what your larger outside case structure will do.
Unread 20-02-2012, 15:39
JChavis's Avatar
Oh, I didn't mean for the two inside structures to mean that it is a part of the program, I just put them there to show different examples...
