Go to Post I guess everyone cant play real defense, like actually pushing the other robot instead of ramming it with the intent to destroy. - Dillon Compton [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 23-01-2012, 03:59
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Encoder rate
What is the Jaguar's maximum encoder rate?
Would a K.O.P. encoder work well as a tachometer (only use channel A) for velocity control when driven directly from a CIM or FischerPrice motor?
Or would some sort of encoder divider (a few flip flops) be needed to reduce the input rate? (with the necessary scaling factors in place in the software to output the correct rate)
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 23-01-2012, 08:17
Re: Encoder rate
If anyone has successfully used the Jaguar's built-in speed control would you please share your experience here?
Unread 23-01-2012, 10:07
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Re: Encoder rate
Reading through the data sheet I got this;
The input frequency of the QEI (Quadrature Encoder Interface) inputs may be as high as 1/4 of the processor frequency (for example, 12.5 MHz for a 50-MHz system)
I double checked the specs of the jag processor just in case and it's 50 MHz.
I hope this helps!
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 23-01-2012, 10:16
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
Re: Encoder rate
I hope this helps!
If you look at the datasheet for the black jaguar, it says 1e6 transitions per second. If you consider that there are 4 transitions used for quadrature encoding you get 250,000 lines per second. With a 100 click per rev encoder you'd get 2500 revs per second. That's 150,000 RPMs. The Jags should handle anything you can throw at them.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 23-01-2012, 16:17
biojae's Avatar
Re: Encoder rate
Haven't tried yet, going to try method 2 first.
( PI loop)
Wanted to make sure that the Jag would be able to handle the high encoder rate before trying it.
Cool. Thanks.
We are going to use just one output (channel A) of a 360 count per revolution encoder.
I don't think that there is a need for direction sensing on our mechanism.
Unread 05-02-2012, 11:42
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
Re: Encoder rate
We are also investigating the same approach, using a Hall effect sensor to control wheel speed.
While this is working for cRIO control, it's proving difficult to close the loop on the Jaguar. I'm aware of the thread on Jaguar speed control http://www.chiefdelphi.com/forums/sh...d.php?t=100135 but we're seeing an even more basic problem with the encoder.
We hooked up the encoder to the Jag input using just 3 wires (+, A, -), and in software set the encoder type to kEncoder (cf kQuadEncoder).
Plotting the value of getSpeed(), we saw a useful signal when the shaft was rotating, but noise around 20kHz when the shaft was stationary rather than the expected zero speed reading.
Investigations continue...
Has anyone got a non-Quad encoder to work with Jaguar closed-loop?
Unread 27-01-2012, 16:25
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Encoder rate
I hope this helps!
I confirmed this too... but I am not sure if there are additional delays due to interupt processing. If I recall correctly, the pic used to have about 10 t0 20 us per interrupt for processing. Maybe a JAG engineer can chime in with respect to actual line/second limits.
Unread 27-01-2012, 17:21
Re: Encoder rate
I suspect the jaguar is using the hardware quadrature decoder, rather then a software interrupt driven routine.
Unread 27-01-2012, 17:51
Re: Encoder rate
http://www.chiefdelphi.com/forums/sh...2&postcount=14
