Thread Tools |
Rating:
Display Modes |
"Compressed Air" vs. "High Pressure Blower"
We are investigating the feasibility of a ball launcher using a cannon design. I want to avoid the complexity of compressed air and use a high pressure blower. Approximate blower specs:
I'd like to use an accumulator (reservoir) but if this will be considered compressed air, this will nix the design (Cv issues). Any thoughts on this subject? Thanks in advance! |
Re: "Compressed Air" vs. "High Pressure Blower"
I'm on my DROID so I can't give you exact text but r73 I think is the number that states the only source of compressed air is the KOP compressor or its equivalent.
Of course, my opinion doesn't count at competition. I would strongly recommend you submit this, carefully worded please, to the official FIRST Q&A system for a ruling. That, you can take to competition. |
I looked at power requirements for a blower @ 750 CFM and 40 inWC (~1.5 PSI) --> 20 HP ballpark. Yikes!
That would require something like sketch below. I think this is getting too complicated and error prone. I'm abandoning this idea... Last edited by DavisDad : 24-01-2012 at 09:58. Reason: spelling |
Your approach of applying some simple estimation techniques to see if your concept is practical is a common and valuable technique in any engineering discipline. Too often people want to cling to an initial concept that does not hold up to this type of analysis and insist on wasting time with prototypes to prove to themselves it won't work. The short build season in FIRST emulates the real world pressures engineering teams often face. The ability to brain storm and quickly come up with a bunch of good ideas for a robot seems like an important skill to succeed here. But equally if not more important is the ability to quickly sort through those ideas to find the few that are actually practical given all the other constraints of the competition. |
I couldn't let go of the idea. I had to know how the leakage around the ball would affect the performance. I rigged up an Extrol tank (hydronic expansion tank) to a short length of Sonotube (big toilet paper tube). The ball is fairly tight with less than 1/16 gap = (tube ID - ball OD)/2. I had my son hold down the rig and I jammed a baseball bat in from the back to get a good force on the diaphragm. The ball went about 10'; OK but not great. A SWAG of the leakage is about 1/2 the volume pushed by the diaphragm leaks by the ball. There is also an affect I've observed from testing with a reversed shop vac:
Maybe there is some back pressure from the leaking air creating high pressure in front of ball (drag). Extrol sketch --> http://www.arttec.net/Solar/12-24-10...gm_diagram.jpg |
#7
As such you may run into issues with <R69> and proving <R73> Quote:
I would recommend a high pressure blower if you are really set on the idea and if it is legal, however I think that this really is not a sound idea. The consistency of it would be very iffy since the ball would be shot out with air, not exactly the best source of power. In addition, if the barrel was constructed wrong the ball would have no rotation as it flew through the air creating a knuckleball effect in which the ball would float at random through the air and would not be able to stay on target. Furthermore, you would need a LOT of air to shoot the ball any further than about 1 foot. The balls are relatively heavy and not light like most air powered projectiles would be. Don't let me stop you from trying this idea, but I really do not think that this would be the best option for any team.
#9
All excellent points. You identified serious drawbacks of this concept and I appreciate the feedback. My son's team is going w/ a spinning disk method. I have my doubts about the accuracy achievable as I helped them build the first prototype. I'm doing this separately as my own investigation. I'm working on an unrelated project with many of the same elements (low pressure, large volume, fast acting, momentary air push). My counter to your concerns:
#10
I made a rig to test the cannon concept. The results were NOT very encouraging. The friction and air leakage losses were significant. The complexity to minimize the lost power and mechanisms to load and release the spring energy would require more work than I'm willing to bet on for this concept.
Anyway... time to focus on the working design. |
#11
Blue Box Quote:
#12
Standard "This is not an official reply" disclaimer applies here:
If I was being asked to inspect such a system, my first question would be "Does the pressure of the air in question at any time exceed atmospheric pressure?" If so, then it is considered "compressed" and all pneumatics / compressor rules apply. |
#13
Fans and blowers, in the past, have been deemed legal and not part of the 'pneumatics system' as long as they were powered by a legal motor. I would Q&A this question, and I would expect a blower system to be legal. Whether it's effective or not is another question ![]() |
#14
During Lunacy, we explored the idea of using blowers to add down force and/or thrust vectoring. We abandoned the idea for feasibility issues.
Sure enough, someone at GSR added some big fans, and didn't seem to have any problems with inspection. Can't remember their number (Peterborough, I think), but it seemed to add to their maneuverability. Compressed air has a far, far higher energy density than the blast of air from a blower, which is why FIRST hasn't seemed to come out against it, so long as the motors are legal (as stated before) and the blades are properly guarded. |
#15
