Go to Post darn design trade-offs! the game design committee does this to us every year! - KenWittlief [more]
Unread 23-01-2012, 13:56
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
F-P gears and Diametral Pitch
Do any of you know what Diametral Pitch each of the gears in the F-P transmissions are? If not, is there a way to calculate the DP of a gear? I want to find this out so I can use that information to calculate the gear spacing in a custom gearbox.
Thanks
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 23-01-2012, 14:29
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: F-P gears and Diametral Pitch
You can calculate diametral pitch with:
Pitch Diameter/Number of Teeth
--Madison--
...down at the Ozdust!
Unread 23-01-2012, 21:46
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Actually, that would be:
number of teeth/pitch diameter
(e.g. 32 teeth/1inch=32DP)
But since pitch diameter is hard to find you can use:
(number of teeth + 2)/Outside diameter
but that is less accurate so a 32DP gear could yield 29.99, or 34. It really works well for some gears, but for others the result will leave you scratching your head.
Unread 23-01-2012, 22:18
Rob Stehlik's Avatar
Rob Stehlik Rob Stehlik is offline
FRC #0610 (Coyotes)
Rob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of lightRob Stehlik is a glorious beacon of light
I highly recommend you measure the shaft spacing in the Fisher Price gearbox and use that in your custom design. I recently counted up the teeth and calculated the pitch diameter of the first two gears (they are 32DP by the way) and made a gearbox based on those numbers. The gears were way too tight! After double checking my numbers and not finding any mistakes, I measured the plastic gearbox, and found the spacing was much larger than expected. I suspect the motor pinion has been profile shifted, which directly changes the center distance.
I'm happy to share my design if you want. Send me a PM.
Unread 23-01-2012, 22:48
AKA: Alan Wells
FRC #1350 (Rambots)
It's always a good idea to design loose, inefficient gear boxes are much more useful than seized gearboxes.
Unread 23-01-2012, 22:54
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Tonight at robot building we were staring at the caliper that was measuring the plastic ring on the FP motor....I was wondering how we were gonna make that funky sized hole with the limited equipment we have available. Then I realized that the orange plastic ring is approximately .040" smaller than 7/8". Since we have to drill a 7/8" hole for the bearings to hold the output shaft, we could drill a 7/8" hole for the motor too, and shim it with a strip of .020" thick aluminum (which we have). This will also let us adjust the gear spacing, by stacking two shims on one side, if we get the spacing wrong.
If this all works, I'll be sure to post some pictures. We're planning to use Lexan plates about 3/16" thick to make the gearbox, and 3/4" long standoffs to hold the sides together.
