Go to Post And (the video) didn't show how to do the "Charlie Brown". I still don't know how to do this... GAH!!!! - Elgin Clock [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 23-01-2012, 16:50
ethen155's Avatar
ethen155 ethen155 is offline
AKA: Ethan
FRC #1831 (Screaming Eagles)
ethen155 is an unknown quantity at this point
The field
Has anyone seen a full field cad for to game in solidworks yet? I know PTC made one but wiht the version of Solidworks that we have, we can't use there CADs. If anyone can give me a link to a download i would very happy
-Thanks
Unread 23-01-2012, 21:29
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
Re: The field
-Thanks
Do you know how to get an updated version of solidworks? As in 2011? Try that first since more companies update anyways and each version is relatively the same. If the course doesn't work with your solidworks, then there won't be a link that will. Basically if it's written in a newer solidworks, the only backwards compatibility is to reduce it to a .step file (which requires a newer version of solidworks or any CAD, of which you don't seem to have) then back to the old version. So you won't be able to get it to your old version or convert it to your version without a newer version of solidworks, so it seems that is your only option. If it was a bought version, solidworks should let you upgrade (I think). If not, PM me.
Unread 25-01-2012, 13:06
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: The field
Please email me directly and I will send you a STEP version of the field.
phil.dollan@autodesk.com
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
