Go to Post ... hey which end of the robot faces the wall anyways? Oops.... :rolleyes: - dhitchco [more]
Unread 23-01-2012, 18:46
Robbie Robinson Robbie Robinson is offline
FRC #0364
Robbie Robinson is an unknown quantity at this point
Labview help
It's my first year with labview and i'm still trying to learn a thing or two. One thing that has had me stumped for a while is that I am trying to get our tank drive to only go backwards. How do I set the variables for this?
Unread 23-01-2012, 19:25
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Smile Re: Labview help
You could try replacing the inputs for the joysticks with -127 witch should send a signal for full reverse on the joysticks and thus make the motors turn in reverse. Have you attempted declaring each motor individually then making it into a drive using its existing motor property.
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 23-01-2012, 23:45
Re: Labview help
What you want to do is unclear. Are you trying to prevent the driver from commanding the robot to go forward? Are you trying to write an autonomous routine?
