Go to Post "Magnificent" is the only appropriate adjective for a handlebar moustache. Kudos. - Lil' Lavery [more]
Unread 24-01-2012, 20:29
inou8it inou8it is offline
Captain/Founder/Student
inou8it has a spectacular aura aboutinou8it has a spectacular aura about
Can't finish drivetrain?
We are trying to build a wide 4 wheel drive using the kitbot. For some reason even though the chain lengths are the same they fight correctly on one side but on the other the back is too tight by only a little bit to put on. Any ideas why this would be? Pics attached.
Thanks!
ID:	11556  Click image for larger version
Unread 24-01-2012, 20:32
Re: Can't finish drivetrain?
Try sliding the transmission on the tight side towards the wheel just a bit to put the chain on.
Unread 24-01-2012, 20:34
nitneylion452's Avatar
AKA: Joe Lee
Try loosening the bolts attaching the gearbox to the frame, then attach your chain and reattach the bolts. That should take care of the problem if your lengths are only off by a little bit.
Joe
"The ones who will one day rule the world rule the basketball court today."
http://www.fatherjudgerobotics.webs.com
Volunteer 2012 MAR Region Championship - Field Reset
Volunteer 2013 MAR Region Championship - Field Reset
Unread 24-01-2012, 20:38
aeniug2's Avatar
aeniug2 aeniug2 is offline
AKA: Joseph
FRC #2879 ("Orange Thunder")
aeniug2 will become famous soon enoughaeniug2 will become famous soon enough
On team 2879 putting the chains on is an event in itself...
We are obsessed with perfectly tight chains, and will struggle for hours to achieve that perfection...
One of the methods we use, aside from loosening the gearbox mounting bolts, is to use 2 small (but strong) screwdrivers to pull the 2 ends of the chain together the last little bit, and have a seconds person quickly insert the connector link thingy.
Unread 24-01-2012, 21:15
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Use the sprocket to force to some extent the chains together enough to fit the master link in. Its hard to explain but the teeth on the sprocket can help to get the chain in place.
Every day is a new adventure!!!
Unread 24-01-2012, 21:49
y-aji y-aji is offline
FRC #3734
y-aji is an unknown quantity at this point
Thank you guys for your answers. Let me give just a little bit more information than was initially given, however, to possibly better explain what we have going on.
It appears to not be a chain length, nor is it a fastening problem. When setting the chains, they are so tight on one side that it bows the wheel inward on the offending side. The other side, using the exact circumference of chain, it is slightly loose. This is true no matter where one slides the gearbox.
I have counted the links, the teeth, and measured the circumference of the chain and found both sides to match each other within a measurable tolerance. However, even though all major variables regarding the chain and distance are the same, we are off by as much as a quarter of an inch when inserting the last screw. I would say it's a squaring issue, however, both the left side and the right side of the drive train have nice strong squares holding them in place.
The only real possibility I can find is that the height of the sprocket is off by 1/8 of an inch or something is wrong with the installation of the gearbox. Can you install a gearbox incorrectly or is it very much so built to prevent any kind of user failure.
The other major factor is, of course, that our robot has an opening in the front of it, we have resolved this temporarily. I'm not sure if the team has confirmed the problem persists from this point.
Unread 24-01-2012, 21:58
aeniug2's Avatar
AKA: Joseph
What exactly do you mean by this?
Is your robot's frame a U shape? And that is somehow a problem?
Unread 24-01-2012, 22:35
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
If you find it's really impossible to do, you may want to look into ordering half links. That being said, chains are funky things - it's a possibility that the chain you're using on the other side has been stretched out (as chain tends to do with wear) which would explain the slack. Measure chain for your application; avoid pre-measured chain lengths.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 24-01-2012, 22:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Is it just me, or does the left rear wheel look like it's out of alignment with the frame?
GitHub
Unread 24-01-2012, 22:53
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
The axle holes in the C-Channel aren't exactly in the center of the channel. When you assemble everything, this means the holes are closer to the top or bottom of the frame. One or two of the channels on your tight side might be upside down relative to your loose side. The easiest visual check is to look at the one hole that's out of line with the rest. Make sure it's shifted in the same direction on all your channels. The correct direction is probably down, which puts the rest of the holes closer to the top of the frame.
Unread 24-01-2012, 23:57
FRC #3734
My oh my that would do it. We'll check that tomorrow.
@aeniug2: we are making a ball collection facility, so we opened the front side of the drive train chassis up to allow the ball to pass through. So, we cut out the front of the robot. That said, it compromises the integrity of the robot to a moderate degree as you no longer have a full square chassis to build the robot on top of. Does that make any sense?
Unread 25-01-2012, 00:01
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I've never seen the chains end up the same length on both sides of our robots.....there's some mystical force in the universe that makes chains always be the wrong length.
We make the chain to fit the robot, and we use half links a lot.
Unread 25-01-2012, 00:04
aeniug2's Avatar
AKA: Joseph
HALF LINKS ARE THE LIFE BLOOD. WITHOUT THEM WE ARE ALL DOOMED... doomed to suffer at the hands of lose chains!
FRC #3734
Haha, you have no idea how much better that makes me feel. I'll just buy a half link.
Unread 25-01-2012, 16:02
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
We seem to use half links a lot as well . . along with master links . . . I've seen 3-4 on a single loop of chain.
