Go to Post The way things generally work in cases like this is simple: if you know something, you can't say it. So keep in mind that if someone does say something, it usually means they don't know. - Alan Anderson [more]
Unread 24-01-2012, 20:31
korsuk19's Avatar
korsuk19 korsuk19 is offline
FRC #3734 (Caxy's)
korsuk19 is an unknown quantity at this point
FRC java build
So, my team and I just formatted our classmate with the FRC USB E11 2012. It all went fine, but I am wondering if we are supposed to re-download the FRC java build for NetBeans IDE or just recopy our own into NB?
thanks.
just wanna learn
Unread 24-01-2012, 22:26
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
Re: FRC java build
You just need to update the FIRST plugins in NetBeans. You don't have to re-install all of NetBeans on each computer.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 26-01-2012, 20:12
korsuk19's Avatar
FRC #3734 (Caxy's)
Re: FRC java build
alright thanks. but do you know what the plugin is called? I can't seem to find it on NB.com
just wanna learn
Unread 27-01-2012, 08:18
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
Re: FRC java build
Add http://first.wpi.edu/FRC/java/netbea...ate/update.xml as a NB plugin.
Unread 27-01-2012, 10:15
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: FRC java build
To expand on nickpeq's correct answer, add the link as an "Update Center" in the "Tools/Plugins/Settings" menu/window/tab.
Unread 27-01-2012, 15:19
korsuk19's Avatar
FRC #3734 (Caxy's)
Re: FRC java build
thank you all.
just wanna learn
Unread 28-01-2012, 15:37
korsuk19's Avatar
FRC #3734 (Caxy's)
Re: FRC java build
again thank you, but now as I try to put the link as a update center it says there is a problem connecting to the proxy. I didn't think FRC needed a proxy for its updates but I guess it does. Does anyone know what the proxy port and name? thanks.
just wanna learn
Unread 29-01-2012, 02:35
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
You shouldn't need a proxy. Unless there is some firewall at your site that requires one.
Brad
Brad Miller
Robotics Resource Center
