Go to Post Please don't act embarrassed if your designs didn't work out; join the club. You are learning and will get better every year. - Gary Dillard [more]
Unread 24-01-2012, 20:43
mickey mickey is offline
FRC #3843
mickey is an unknown quantity at this point
problem getting motor control with the 2012 default code
I loaded the default 2012 Labview code to my team's last year's robot, but all of the sidecar functions (relay, DIO, PWM) do not work. I testted setting a solenoid and that turned on and off, but I could not set the pwm motor controller that was on the sidecar.
Any ideas of what I am doing wrong? The wiring seems to be correct, and I am practically using the default code.
Unread 24-01-2012, 23:03
Re: problem getting motor control with the 2012 default code
Did you rearrange the hardware modules in last year's cRIO?
Did you reimage last year's cRIO?
The digital module now belongs and is expected by the code to be in slot 2.
And the 2012 default code expects the 2012 image on the cRIO.
Unread 25-01-2012, 23:56
FRC #3843
I had the crio modules set for last years configuration ( DIO module in slot 4). I changed the DIO module to slot 2 and the robot ran just fine! Thanks.
