Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 25-01-2012, 20:09
InvisoTech InvisoTech is offline
FRC #4159
InvisoTech is an unknown quantity at this point
Motor Attachments
Hi,
I want to attach parts to my motor and I need to use some form of keying to attach them. The part I want to buy online says it has "standard keying." I was wondering what that means, I cant find the standard dimensions of the key online.
Please help. Thank you.
Unread 25-01-2012, 20:12
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Motor Attachments
If you can link to the part online, we might be able to help you further. Which motor are you trying to attach to?
CIM's use a 2mm key
Most AndyMark gearboxes (including your Kit of Part gearbox) use a 1/8" key.
None of the other motors have keyways. Usually the gears are pressed onto the shafts.
http://www.andymark.com/Machine-Keys-s/83.htm
GitHub
