Go to Post Remember, there are many differents path to obtaining knowledge. There's no need to pigeonhole the process. - Karthik [more]
Unread 26-01-2012, 06:49
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
Nivision.h Compiler Errors
I wrote a script using the Vision Assistant, and exported the C code to run in WindRiver. When I try to build the project however, I get an enormous amount of error messages. They're not from the C file, no, they're from nivision.h. There are >1000 errors that get printed trying to compile nivision.h. What should I do? I did try to just implement the nivision libraries by myself, and I get the same compiler errors. Every time it tries to compile, it just gives a huge pile of errors. Help!
Thanks in advance!
-Arthur
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
Unread 11-02-2013, 18:22
ronbaer ronbaer is offline
FRC #0612 (Chantilly Robotics)
ronbaer is an unknown quantity at this point
Re: Nivision.h Compiler Errors
While this is an old post, the answer is still useful. (And I had the same problem today.)
Answer: Set the build environment to PPC603gnu
