Thread Tools |
Rating:
Display Modes |
Error: org.apache.commons.net.io.CopyStreamException: IOException caught while copyin
In NetBeans 7.1, i am running the "cameraTest.java" program given to us by FRC. I have turned off the firewall found in my Norton Internet Security Version 19.2.0.10, and the two firewalls found in my Windows 7.
I also executed: netsh advfirewall set global StatefulFTP disable. That fixed my old error, but this one came up this time: org.apache.commons.net.io.CopyStreamException: IOException caught while copying. Anyone know how i can fix this? |
Re: Error: org.apache.commons.net.io.CopyStreamException: IOException caught while co
Here is the I get when i run the program. Any and all help appreciated!
init: init: Deleting directory C:\Users\Geoffrey\Documents\Robotics\YetiBot\build Deleting directory C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Deleting directory C:\Users\Geoffrey\Documents\Robotics\YetiBot\j2mec lasses clean: Created dir: C:\Users\Geoffrey\Documents\Robotics\YetiBot\build Compiling 2 source files to C:\Users\Geoffrey\Documents\Robotics\YetiBot\build compile: Created dir: C:\Users\Geoffrey\Documents\Robotics\YetiBot\j2mec lasses preverify: Created dir: C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Building jar: C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite \YetiBot_1.0.0.jar jar-app: CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods [translating suite image [closed: false, parent: squawk] ...] ### Excluding compile: com.sun.squawk.Method::getParameterTypes ### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt [Including resource: META-INF/MANIFEST.MF] Romizer processed 156 classes and generated 4 files. Expanding: C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite \YetiBot_1.0.0.jar into C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Moving 1 file to C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Moving 1 file to C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Moving 1 file to C:\Users\Geoffrey\Documents\Robotics\YetiBot\suite Deleting: C:\Users\Geoffrey\Documents\Robotics\YetiBot\image .suite.api Host OS: Windows 7 6.1, 6.1 Host JVM: Java HotSpot(TM) Client VM 21.0-b17 Target IP: 10.35.6.2 Network interfaces on host: Broadcom NetLink (TM) Gigabit Ethernet: address: 10.104.26.150 netmask: 255.255.255.0 Intel(R) WiFi Link 5100 AGN: address: 10.35.6.8 netmask: 255.255.255.254 WARNING: Host is not on same subnet as robot. May not be able to complete all communication with robot. Connecting FTP @10.35.6.2 C:\Users\Geoffrey\sunspotfrcsdk\build.xml:96: The following error occurred while executing this line: C:\Users\Geoffrey\sunspotfrcsdk\ant\upgrade.xml:40 : org.apache.commons.net.io.CopyStreamException: IOException caught while copying. at org.apache.commons.net.io.Util.copyStream(Util.jav a:130) at org.apache.commons.net.ftp.FTPClient.retrieveFile( FTPClient.java:1611) at com.sun.spot.sdk.tool.ftp.UpgradeTask.upgrade(Upgr adeTask.java:302) at com.sun.spot.sdk.tool.ftp.UpgradeTask.execute(Upgr adeTask.java:216) at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291) at sun.reflect.GeneratedMethodAccessor69.invoke(Unkno wn Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:39 0) at org.apache.tools.ant.Target.performTasks(Target.ja va:411) at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1399) at org.apache.tools.ant.helper.SingleCheckExecutor.ex ecuteTargets(SingleCheckExecutor.java:38) at org.apache.tools.ant.Project.executeTargets(Projec t.java:1251) at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java :442) at org.apache.tools.ant.taskdefs.CallTarget.execute(C allTarget.java:105) at org.apache.tools.ant.UnknownElement.execute(Unknow nElement.java:291) at sun.reflect.GeneratedMethodAccessor69.invoke(Unkno wn Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:601) at org.apache.tools.ant.dispatch.DispatchUtils.execut e(DispatchUtils.java:106) at org.apache.tools.ant.Task.perform(Task.java:348) at org.apache.tools.ant.Target.execute(Target.java:39 0) at org.apache.tools.ant.Target.performTasks(Target.ja va:411) at org.apache.tools.ant.Project.executeSortedTargets( Project.java:1399) at org.apache.tools.ant.Project.executeTarget(Project .java:1368) at org.apache.tools.ant.helper.DefaultExecutor.execut eTargets(DefaultExecutor.java:41) at org.apache.tools.ant.Project.executeTargets(Projec t.java:1251) at org.apache.tools.ant.module.bridge.impl.BridgeImpl .run(BridgeImpl.java:285) at org.apache.tools.ant.module.run.TargetExecutor.run (TargetExecutor.java:539) at org.netbeans.core.execution.RunClassThread.run(Run ClassThread.java:153) BUILD FAILED (total time: 11 seconds) |
Check the netmask setting on your developer machine's wifi network connection. It should be 255.255.255.0, but it looks like its 255.255.255.254.
