Go to Post The awards may or may not come...but the real trophies are the students. - David Brinza [more]
Unread 26-01-2012, 22:39
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
Powering a Conveyor Roller
Hi, CD
Team 1515 ran into a dilemma when finding out that the 3/8" keyed shaft from McMaster is backordered, basically until stop-build day. Our design as is involves 2.5" ABS (tubular) fixed to AM Hubs run on a live axle.
Both the 3/8" AM Hubs and the 3/8" McMaster shaft are currently out of stock.
We would like to ask the CD community what other teams suggest in terms of powering the rollers. Our two constraints are: 3/8" shaft DIA and quick. Ideally, we would like to use a live axle setup.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
Unread 26-01-2012, 22:47
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Re: Powering a Conveyor Roller
How about MSC or Grainger? Both have presence in LA area and you should be able to get what you need quickly.
Unread 26-01-2012, 22:50
AdamHeard's Avatar
Lead Mentor
Originally Posted by msimon785 View Post
Hi, CD
Joe got you set up with shaft, if you need hubs order anything from AM with a smaller bore, and we'll gladly bore out and broach them for you.
Unread 26-01-2012, 23:17
AKA: Mathew Simon
Thanks so much!
MSC has everything we need to go about this. We will order the 10mm AM hubs instead of the 3/8" its a difference of .001", which is more than marginal.
To Adam, if we need any lathe-work, I'll make sure to contact you. Thank you for your support.
Mathew Simon
CAD/Design
Unread 26-01-2012, 23:46
AdamHeard's Avatar
Lead Mentor
Thanks so much!
10mm is more like .394
Unread 26-01-2012, 23:56
AKA: Mathew Simon
Hm. AndyMark is wrong. @AndyBaker, you should probably fix that.
Bore: 10mm (0.374 inch), with a 4mm (0.157 inch) keyway
Mathew Simon
CAD/Design
Unread 27-01-2012, 00:01
pfreivald's Avatar
AKA: Patrick Freivald
Find local machine shops, or really anyone with a mill (were we closer, we'd do it for you... and if you want to pay shipping, we still will!) Keying a shaft is trivial with the right equipment, and 3/8" steel bar stock is ubiquitous.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 27-01-2012, 00:12
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
We just did this a few times with only basic machining equipment. I am sure you can find someone that can do it for you.
We are powering our rollers with polycod, stick a pully on the drive shaft of the motor and lathe a grove into roller.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 27-01-2012, 12:52
AKA: Mathew Simon
After searching through McMaster, the 10mm roller bearings have identical mounts to the .375". We're just going to switch out the bearings.
Thanks, everyone
Mathew Simon
CAD/Design
