Go to Post I'm excited. Probably too much, but eh, I'm a big geek. - Brandon Martus [more]
Unread 27-01-2012, 09:58
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Balls under the bumper
Has anybody noticed the balls tend to roll under the bumpers rather than bounce off of them. Even with the with the bumper at the 2" height?
Unread 27-01-2012, 11:00
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
Re: Balls under the bumper
Yeah we are working on ways to prevent this. Add in trying to go over the bridge and this makes for one more thing to work into the design.
We might get some of those Uncle Sam mudflaps and put those around the bot
Unread 27-01-2012, 11:02
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We haven't got that far yet...thanks for the info. Might be that we want a full bellypan.
Unread 27-01-2012, 11:04
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
We've also found that the balls like to go under the bumper, even with a 3.5-4" ground clearance.
Unread 27-01-2012, 11:06
MrForbes's Avatar
AKA: Jim
I guess we shoulda spent more time playing before we designed our robot...sigh...
Unread 27-01-2012, 11:35
1493kd's Avatar
kd
FRC #1493 (FALCONS)
I am interested to see how hard/liberal they are with the penalties for getting a 4th ball "into" your robot. I think some teams with 3 balls already in possession are going to end of playing dodge ball on the field in hopes of not gettings a penalty.
Unread 27-01-2012, 11:41
MrForbes's Avatar
AKA: Jim
I guess it depends on whether or not you're "controlling" the ball under the robot
[G22]
Robots may only actively control three Basketballs at any time.
Violation: Foul per extra Basketball
Moving or positioning a Basketball to gain advantage is considered actively controlling. Examples are “carrying” (holding Basketballs in the Robot), “herding” (intentionally pushing or impelling Basketballs to a desired location or direction) and “trapping” (pressing one or more Basketballs against a Court element in an attempt to shield them).
Examples of Basketball interaction that are not actively controlling are “bulldozing” (inadvertently coming in contact with Basketballs that happen to be in the path of the Robot as it drives down the Court) and “deflecting” (being hit by a propelled Basketball that bounces or rolls off the Robot).
A Basketball that becomes unintentionally lodged on a Robot will be considered controlled by the Robot. It is important to design your Robot so that it is impossible to inadvertently or intentionally control more than three Basketballs at a time.
Unread 27-01-2012, 12:04
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
In 2010 there ended up being a lot more ball entering the frame perimeter penalties than expected, as many of you may remember. Towards the end of the season, they changed the rules to be a bit more generous and I wouldn't be surprised if they do something like that again.
Unread 27-01-2012, 12:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I would be a bit surprised if they did this considering every team can drop their bumpers low enough to prevent any incursions (at the cost of mobility, potentially). Also because a team can always just carry 2 balls when driving around the field, they do not have to carry 3.
In contrast to 2010 where incursion was a specific rule as you say, in 2012 a robot can legally drive over a ball, only other choices/avoidable scenarios make this potentially illegal.
Unread 27-01-2012, 12:12
MrForbes's Avatar
AKA: Jim
I guess we need to try it ourselves, to see which of you is correct?
Unread 27-01-2012, 12:15
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
We tried with some older bumpers, anything much below 3" seemed to work quite well. Maybe something in one of our respecitve test setups wasn't quite legit?
Unread 01-02-2012, 16:07
jon-s's Avatar
jon-s jon-s is offline
Lead Designer
FRC #3335
jon-s is an unknown quantity at this point
In the section of the rules about the game fouls, it says that fouls caused by the opposing alliance will not be counted. Nothing against one of your team-mates jamming a ball into your robot.
Jon. S
