Go to Post Viva La FIRST Revolucion! - phrontist [more]
Unread 28-01-2012, 08:26
mr_yes mr_yes is offline
FRC #1248 (The TITANium Allies)
mr_yes has a spectacular aura aboutmr_yes has a spectacular aura about
Netbeans can't load DefaultCodeProject
We are starting on Java with Netbeans from scratch this year, and are having problems getting going. When we attempt to load the DefaultCodeProject into a new project, in step 2 it goes to the Target Location screen, which is not described in the manual. I suspect that the DefaultCodeProject is either missing or a link to it is bad. Anyone see this before?
Unread 28-01-2012, 13:51
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Re: Netbeans can't load DefaultCodeProject
I have had the same issue, but only since the January 21 update. If you need it, I have the code for the Default Program.
Here:
/* Copyright (c) FIRST 2008. All Rights Reserved. */
/* Open Source Software - may be modified and shared by FRC teams. The code */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project. */
package edu.wpi.first.wpilibj.defaultCode;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
* This "BuiltinDefaultCode" provides the "default code" functionality as used
* in the "Benchtop Test."
* The BuiltinDefaultCode extends the IterativeRobot base class to provide the
* "default code" functionality to confirm the operation and usage of the core
* control system components, as used in the "Benchtop Test" described in
* Chapter 2 of the 2009 FRC Control System Manual.
* This program provides features in the Disabled, Autonomous, and Teleop modes
* as described in the benchtop test directions, including "once-a-second"
* debugging printouts when disabled, a "KITT light show" on the solenoid lights
* when in autonomous, and elementary driving capabilities and "button mapping"
* of joysticks when teleoperated. This demonstration program also shows the use
* of the user watchdog timer.
* This demonstration is not intended to serve as a "starting template" for
* development of robot code for a team, as there are better templates and
* examples created specifically for that purpose. However, teams may find the
* techniques used in this program to be interesting possibilities for use in
* their own robot code.
* The details of the behavior provided by this demonstration are summarized
* below:
* Disabled Mode: - Once per second, print (on the console) the number of
* seconds the robot has been disabled.
* Autonomous Mode: - Flash the solenoid lights like KITT in Knight Rider -
* Example code (commented out by default) to drive forward at half-speed for 2
* seconds
* Teleop Mode: - Select between two different drive options depending upon
* Z-location of Joystick1 - When "Z-Up" (on Joystick1) provide "arcade drive"
* on Joystick1 - When "Z-Down" (on Joystick1) provide "tank drive" on Joystick1
* and Joystick2 - Use Joystick buttons (on Joystick1 or Joystick2) to display
* the button number in binary on the solenoid LEDs (Note that this feature can
* be used to easily "map out" the buttons on a Joystick. Note also that if
* multiple buttons are pressed simultaneously, a "15" is displayed on the
* solenoid LEDs to indicate that multiple buttons are pressed.)
* This code assumes the following connections: - Driver Station: - USB 1 - The
* "right" joystick. Used for either "arcade drive" or "right" stick for tank
* drive - USB 2 - The "left" joystick. Used as the "left" stick for tank drive
* - Robot: - Digital Sidecar 1: - PWM 1/3 - Connected to "left" drive motor(s)
* - PWM 2/4 - Connected to "right" drive motor(s)
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class DefaultRobot extends IterativeRobot {
// Declare variable for the robot drive system
RobotDrive m_robotDrive; // robot will use PWM 1-4 for drive motors
int m_dsPacketsReceivedInCurrentSecond; // keep track of the ds packets received in the current second
// Declare variables for the two joysticks being used
Joystick m_rightStick; // joystick 1 (arcade stick or right tank stick)
Joystick m_leftStick; // joystick 2 (tank left stick)
static final int NUM_JOYSTICK_BUTTONS = 16;
boolean[] m_rightStickButtonState = new boolean[(NUM_JOYSTICK_BUTTONS + 1)];
boolean[] m_leftStickButtonState = new boolean[(NUM_JOYSTICK_BUTTONS + 1)];
// Declare variables for each of the eight solenoid outputs
static final int NUM_SOLENOIDS = 8;
Solenoid[] m_solenoids = new Solenoid[NUM_SOLENOIDS];
// drive mode selection
static final int UNINITIALIZED_DRIVE = 0;
static final int ARCADE_DRIVE = 1;
static final int TANK_DRIVE = 2;
int m_driveMode;
// Local variables to count the number of periodic loops performed
int m_autoPeriodicLoops;
int m_disabledPeriodicLoops;
int m_telePeriodicLoops;
* Constructor for this "BuiltinDefaultCode" Class.
* The constructor creates all of the objects used for the different inputs
* and outputs of the robot. Essentially, the constructor defines the
* input/output mapping for the robot, providing named objects for each of
* the robot interfaces.
public DefaultRobot() {
System.out.println("BuiltinDefaultCode Constructor Started\n");
// Create a robot using standard right/left robot drive on PWMS 1, 2, 3, and #4
m_robotDrive = new RobotDrive(1, 2);
m_dsPacketsReceivedInCurrentSecond = 0;
// Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
m_rightStick = new Joystick(1);
m_leftStick = new Joystick(2);
// Iterate over all the buttons on each joystick, setting state to false for each
int buttonNum = 1; // start counting buttons at button 1
for (buttonNum = 1; buttonNum <= NUM_JOYSTICK_BUTTONS; buttonNum++) {
m_rightStickButtonState[buttonNum] = false;
m_leftStickButtonState[buttonNum] = false;
// Iterate over all the solenoids on the robot, constructing each in turn
int solenoidNum = 1; // start counting solenoids at solenoid 1
for (solenoidNum = 0; solenoidNum < NUM_SOLENOIDS; solenoidNum++) {
m_solenoids[solenoidNum] = new Solenoid(solenoidNum + 1);
// Set drive mode to uninitialized
m_driveMode = UNINITIALIZED_DRIVE;
// Initialize counters to record the number of loops completed in autonomous and teleop modes
m_autoPeriodicLoops = 0;
m_disabledPeriodicLoops = 0;
m_telePeriodicLoops = 0;
System.out.println("BuiltinDefaultCode Constructor Completed\n");
* ******************************** Init Routines ************************************
public void robotInit() {
// Actions which would be performed once (and only once) upon initialization of the
// robot would be put here.
System.out.println("RobotInit() completed.\n");
public void disabledInit() {
m_disabledPeriodicLoops = 0; // Reset the loop counter for disabled mode
ClearSolenoidLEDsKITT();
startSec = (int) (Timer.getUsClock() / 1000000.0);
printSec = startSec + 1;
public void autonomousInit() {
m_autoPeriodicLoops = 0; // Reset the loop counter for autonomous mode
public void teleopInit() {
m_telePeriodicLoops = 0; // Reset the loop counter for teleop mode
m_dsPacketsReceivedInCurrentSecond = 0; // Reset the number of dsPackets in current second
m_driveMode = UNINITIALIZED_DRIVE; // Set drive mode to uninitialized
* ******************************** Periodic Routines ************************************
static int printSec;
static int startSec;
public void disabledPeriodic() {
// feed the user watchdog at every period when disabled
Watchdog.getInstance().feed();
// increment the number of disabled periodic loops completed
m_disabledPeriodicLoops++;
// while disabled, printout the duration of current disabled mode in seconds
if ((Timer.getUsClock() / 1000000.0) > printSec) {
System.out.println("Disabled seconds: " + (printSec - startSec));
printSec++;
public void autonomousPeriodic() {
// feed the user watchdog at every period when in autonomous
m_autoPeriodicLoops++;
// generate KITT-style LED display on the solenoids
SolenoidLEDsKITT(m_autoPeriodicLoops);
* the below code (if uncommented) would drive the robot forward at half
* speed for two seconds. This code is provided as an example of how to
* drive the robot in autonomous mode, but is not enabled in the default
* code in order to prevent an unsuspecting team from having their robot
* drive autonomously!
//below code commented out for safety
if (m_autoPeriodicLoops == 1) {
// When on the first periodic loop in autonomous mode, start driving forwards at half speed
m_robotDrive.drive(1.0, 0.0); // drive forwards at half speed
if (m_autoPeriodicLoops == (2 * GetLoopsPerSec())) {
// After 2 seconds, stop the robot
m_robotDrive.drive(0.0, 0.0); // stop robot
public void teleopPeriodic() {
// increment the number of teleop periodic loops completed
m_telePeriodicLoops++;
* Code placed in here will be called only when a new packet of
* information has been received by the Driver Station. Any code which
* needs new information from the DS should go in here
m_dsPacketsReceivedInCurrentSecond++; // increment DS packets received
// put Driver Station-dependent code here
// Demonstrate the use of the Joystick buttons
Solenoid[] firstGroup = new Solenoid[4];
Solenoid[] secondGroup = new Solenoid[4];
for (int i = 0; i < 4; i++) {
firstGroup[i] = m_solenoids[i];
secondGroup[i] = m_solenoids[i + 4];
DemonstrateJoystickButtons(m_rightStick, m_rightStickButtonState, "Right Stick", firstGroup);
DemonstrateJoystickButtons(m_leftStick, m_leftStickButtonState, "Left Stick ", secondGroup);
// determine if tank or arcade mode, based upon position of "Z" wheel on kit joystick
if (m_rightStick.getZ() <= 0) { // Logitech Attack3 has z-polarity reversed; up is negative
// use arcade drive
m_robotDrive.arcadeDrive(m_rightStick, false); // drive with arcade style (use right stick)
if (m_driveMode != ARCADE_DRIVE) {
// if newly entered arcade drive, print out a message
System.out.println("Arcade Drive\n");
m_driveMode = ARCADE_DRIVE;
} else {
// use tank drive
m_robotDrive.tankDrive(m_leftStick, m_rightStick); // drive with tank style
if (m_driveMode != TANK_DRIVE) {
// if newly entered tank drive, print out a message
System.out.println("Tank Drive\n");
m_driveMode = TANK_DRIVE;
* Clear KITT-style LED display on the solenoids
* Clear the solenoid LEDs used for a KITT-style LED display.
public void ClearSolenoidLEDsKITT() {
// Iterate over all the solenoids on the robot, clearing each in turn
m_solenoids[solenoidNum].set(false);
* Generate KITT-style LED display on the solenoids
* This method expects to be called during each periodic loop, with the
* argument being the loop number for the current loop.
* The goal here is to generate a KITT-style LED display. (See
* http://en.wikipedia.org/wiki/KITT ) However, since the solenoid module
* has two scan bars, we can have ours go in opposite directions! The scan
* bar is written to have a period of one second with six different
* positions.
public void SolenoidLEDsKITT(int numloops) {
final int NUM_KITT_POSITIONS = 6;
int numloop_within_second = numloops % GetLoopsPerSec();
// note that the array index values below are zero-based, but solonoid numbers are one based.
if (numloop_within_second == 0) {
// position 1; solenoids 1 and 8 on
m_solenoids[0].set(true);
m_solenoids[7].set(true);
m_solenoids[1].set(false);
m_solenoids[6].set(false);
} else if (numloop_within_second == (GetLoopsPerSec() / NUM_KITT_POSITIONS)) {
// position 2; solenoids 2 and 7 on
m_solenoids[1].set(true);
m_solenoids[6].set(true);
m_solenoids[0].set(false);
m_solenoids[7].set(false);
} else if (numloop_within_second == (GetLoopsPerSec() * 2 / NUM_KITT_POSITIONS)) {
// position 3; solenoids 3 and 6 on
m_solenoids[2].set(true);
m_solenoids[5].set(true);
} else if (numloop_within_second == (GetLoopsPerSec() * 3 / NUM_KITT_POSITIONS)) {
// position 4; solenoids 4 and 5 on
m_solenoids[3].set(true);
m_solenoids[4].set(true);
m_solenoids[2].set(false);
m_solenoids[5].set(false);
} else if (numloop_within_second == (GetLoopsPerSec() * 4 / NUM_KITT_POSITIONS)) {
// position 5; solenoids 3 and 6 on
m_solenoids[3].set(false);
m_solenoids[4].set(false);
} else if (numloop_within_second == (GetLoopsPerSec() * 5 / NUM_KITT_POSITIONS)) {
// position 6; solenoids 2 and 7 on
int GetLoopsPerSec() {
return 20;
* Demonstrate handling of joystick buttons
* This method expects to be called during each periodic loop, providing the
* following capabilities: - Print out a message when a button is initially
* pressed - Solenoid LEDs light up according to joystick buttons: - When no
* buttons pressed, clear the solenoid LEDs - When only one button is
* pressed, show the button number (in binary) via the solenoid LEDs - When
* more than one button is pressed, show "15" (in binary) via the solenoid
* LEDs
public void DemonstrateJoystickButtons(Joystick currStick,
boolean[] buttonPreviouslyPressed,
String stickString,
Solenoid solenoids[]) {
boolean outputGenerated = false; // flag for whether or not output is generated for a button
int numOfButtonPressed = 0; // 0 if no buttons pressed, -1 if multiple buttons pressed
* Iterate over all the buttons on the joystick, checking to see if each
* is pressed If a button is pressed, check to see if it is newly
* pressed; if so, print out a message on the console
if (currStick.getRawButton(buttonNum)) {
// the current button is pressed, now act accordingly...
if (!buttonPreviouslyPressed[buttonNum]) {
// button newly pressed; print out a message
if (!outputGenerated) {
// print out a heading if no other button pressed this cycle
outputGenerated = true;
System.out.println("button pressed:" + stickString);
System.out.println(" " + buttonNum);
// remember that this button is pressed for the next iteration
buttonPreviouslyPressed[buttonNum] = true;
// set numOfButtonPressed appropriately
if (numOfButtonPressed == 0) {
// no button pressed yet this time through, set the number correctly
numOfButtonPressed = buttonNum;
} else {
// another button (or buttons) must have already been pressed, set appropriately
numOfButtonPressed = -1;
} else {
buttonPreviouslyPressed[buttonNum] = false;
// after iterating through all the buttons, add a newline to output if needed
if (outputGenerated) {
System.out.println("\n");
if (numOfButtonPressed == -1) {
// multiple buttons were pressed, display as if button 15 was pressed
DisplayBinaryNumberOnSolenoidLEDs(15, solenoids);
} else {
// display the number of the button pressed on the solenoids;
// note that if no button was pressed (0), the solenoid display will be cleared (set to 0)
DisplayBinaryNumberOnSolenoidLEDs(numOfButtonPress ed, solenoids);
* Display a given four-bit value in binary on the given solenoid LEDs
void DisplayBinaryNumberOnSolenoidLEDs(int displayNumber, Solenoid[] solenoids) {
if (displayNumber > 15) {
// if the number to display is larger than can be displayed in 4 LEDs, display 0 instead
displayNumber = 0;
solenoids[3].set((displayNumber & 1) != 0);
solenoids[2].set((displayNumber & 2) != 0);
solenoids[1].set((displayNumber & 4) != 0);
solenoids[0].set((displayNumber & 8) != 0);
Hope this helps!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
