Go to Post Duct tape can fix everything except relationships with other people. - dixonij [more]
Unread 28-01-2012, 10:23
Murphys_Outlaws Murphys_Outlaws is offline
FRC #0677
Murphys_Outlaws is an unknown quantity at this point
Trouble with xbox 360 controller in LabVIEW
Hi,
We are coding an xBox 360 controller in LabVIEW and are having trouble getting the robot code to recognize any input values. We have opened the controller as a joystick and wired in LabVIEW the button and axis outputs to code. Currently, all the lights on our Jaguars are still flashing orange.
Anyone have any solutions to this problem?
Unread 28-01-2012, 12:20
kdehaan42 kdehaan42 is offline
FRC #2874 (Eagles)
kdehaan42 is an unknown quantity at this point
Re: Trouble with xbox 360 controller in LabVIEW
We also use xbox controllers to run our robot upload a picture of the code and I will see if I can help.
Unread 28-01-2012, 12:39
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
Theres actually a very simple way to test the values output by a controller. just put all of the values to the motor outputs and run the code from robot main. Dont deply. And then probe the values in the teleop.vi . If its not outputing values then you have 1 of 2 problems
Your controller is in the wrong port or you cant use the controller. Make sure you're using the PC version of the 360 Controller.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
Unread 28-01-2012, 15:18
porterma64's Avatar
porterma64 porterma64 is offline
FRC #0815 (Advanced Power)
Team Role: Electrical
porterma64 is an unknown quantity at this point
First, check to see if you have drivers installed. Go online for microsoft updates.
Second, look at the Labview examples for joystick controls and look at mapping the inputs to outputs. When you run the vi you will check to see if the motion from the front panel corresponds to the input action on the controller. Record your findings for future programming. You may need to modify the joystick vi to show all switch & joystick inputs on the front panel.
Unread 28-01-2012, 16:37
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Go to the diagnostics or setup tab in the driver station and tell us if your gamepad is showing up. If it is not, you may be using a non-standard xbox controller (non-pc standard), and you will have to go get drivers to make it work.
However, that should not affect your jaguars. If they are getting a proper PWM signal, they should be solid orange. Are all the lights on your digital side car lit correctly?
Unread 29-01-2012, 00:49
Did you enable the robot?
