Go to Post If you want to change the culture sometimes you need to change a little yourself - Koko Ed [more]
Unread 30-01-2012, 01:21
gh2o gh2o is offline
FRC #4159
gh2o is on a distinguished road
BotHS: A Java web framework for your cRIO
BotHS is a Java framework that allows you to communicate with your robot via HTTP. If you feel like Dashboard or SmartDashboard are too limiting for you, you can design your own web interface for controlling data from and to the robot! You will also have access to the low-overhead HTML5 WebSocket protocol, allowing for fast and easy bidirectional communication.
If you're in doubt, give it a try! Five lines of code is all you need.
-> https://github.com/gh2o/BotHS <-
This framework is still in beta (possibly even alpha), so if you find any problems, please report them.
Unread 30-01-2012, 01:40
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: BotHS: A Java web framework for your cRIO
Looks very cool! Are you guys using this for your dashboard? Would you be willing to release the code you are using to display your robot's info?
- Oliver
Unread 30-01-2012, 15:18
shuhao shuhao is offline
FRC #4069 (Lo-Ellen Robotics)
shuhao is an unknown quantity at this point
Looks like what I have, except the server is hosted on an actual computer than the robot
