Go to Post I'll do my best, but I'm this --><-- close to telling our drivers they're NASCAR styling it this season..."Sorry boys and girls, left turns only!" - Mr. Lim [more]
Unread 31-01-2012, 15:06
NeatTeam NeatTeam is offline
FRC #1943
NeatTeam is an unknown quantity at this point
Updating eclipse
When i entered to Eclipse then Help==>Install new software, this error message appered:
Some sites could not be found. See the error log for more detail.
No repository found at http://first.wpi.edu/FRC/c/eclipse/update/.
No repository found at http://download.eclipse.org/eclipse/updates/3.7.
No repository found at http://download.eclipse.org/releases/indigo.
No repository found at http://first.wpi.edu/FRC/java/eclipse/update/.
No repository found at http://download.eclipse.org/mylyn/releases/indigo.
No repository found at https://first.wpi.edu/FRC/c/eclipse/update/.
The eclipse could not find the update website which i can easly access from the browser.
Unread 31-01-2012, 19:42
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Re: Updating eclipse
Are you behind a firewall of some kind? If your browser is set up to connect through a firewall, Eclipse may not be able to do so unless it is specially set up. The fact that you cannot connect to some of the standard Eclipse download sites indicates an IDE-level problem.
Have you ever been able to update this installation of Eclipse from your current machine? (Aka biggest info needed is whether this is a change or has been a problem since day 1 of using Eclipse, this will help figure out the specific issue occurring)
CRUD Name: Windows
Alumni to Team: 350
