Go to Post Obligatory warning: School comes first. If you have to choose between doing homework and going to a build season meeting, do the homework. - Billfred [more]
View Poll Results: "Shooter" or "Dumper"?
Shooter 145 87.88%
Dumper 20 12.12%
Voters: 165. You may not vote on this poll
Unread 31-01-2012, 19:03
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Shooter or Dumper?
My team is currently deciding between whether we want to "shoot" the balls, or go up close and "dump" the balls, into the hoops. Due to the rules, a dumper could only hit the second hoop, unless the appendage stuff changes. But shooters are clearly less accurate. So, I'm asking CD's opinion. What do you guys think? (See poll at top of page.)
http://www.chiefdelphi.com/forums/sh...=100788&page=2
Another poll of mine, if you're interested.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
Unread 31-01-2012, 19:12
Re: Shooter or Dumper?
Yes, a shooter will miss shots. That's better than not being able to take any because a defender parks in your way or jostles you hard. And there are going to be some very accurate shooters.
Unread 31-01-2012, 20:09
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Your best option is to make a shooter that has the option of dumping. Shooting is going to be harder, it will be a lot easier to add a dumping option later than it will be to add a shooter.
Unread 31-01-2012, 20:10
Da' Rule Man
AKA: Nik Shepherd
Personally, I agree, but my team still has some dissent, even though a shooter is clearly the majority vote.
Unread 31-01-2012, 20:15
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
You guys need to decide ASAP. This is week four and if you haven't decided yet you are at least a week behind.
I would suggest to do whichever you can get done quickly.
Unread 31-01-2012, 20:17
Billfred's Avatar
Billfred Billfred is offline
Agree with IndySam. You have 21 days until it has to be in the bag. Whatever your strategy (and there are several not listed here, mind you--including some that may be better moves at this stage of the game), you need to settle on it ASAP. Clock's a-ticking.
Unread 31-01-2012, 21:48
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
We have decided and have been working on it since the first week. There were some thoughts to the other way of doing things that a few students still wished to pursue and have the rest of the team consider, that's all.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 31-01-2012, 21:53
Andrew Lawrence
Posts: n/a
It depends on your robot and strategies.
For us, we plan on doing both. We will have a shooter that can shoot far, but our main offensive strategy is to be a fast collector and dump our balls into the middle hoop really fast, and then get more balls. Just slam up against the fender, fire away, and then get away really quickly to gather more balls.
In a test run of this, we successfully out-maneuvered the defending robot and were able to rack up points pretty quickly.
We shoot far if we're feeding from the other side of the field, or in autonomous.
Unread 31-01-2012, 21:57
pfreivald's Avatar
AKA: Patrick Freivald
We are building a shooter that can be easily retrofitted to a dunker if the shooting challenge doesn't work out (consistency is difficult; we're not yet sure how difficult -- it's quite the challenge to shoot balls at the correct speed and angle, much less in the right direction, and this problem is daunting on both the programming and the mechanical side.)
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 31-01-2012, 22:41
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
We have not decided a style of shooter, but the way we are going right now it looks like we will be able to succesfully dump and shoot balls. I would have to agree with all of the people before me that said that you should be able to do both effectivly.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 31-01-2012, 23:09
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
We have a robot rite now inthe middle of shooter and dumper our shooter is within a day or to from being completed and our dumper will be functiion by the middle of the next week.We decided to throw it on in case their no defenders.See ya at CHeaspeake regional
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 31-01-2012, 23:32
FRC #1836 (MilkenKnights)
I personally consider shooting in the top basket while touching the fender to be dumping, If that is the case, then I believe dumping is the far better strategy.
Unread 01-02-2012, 00:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Our team is going with a shooter. It is much more risky than a dumper, but with a practice robot and some excellent programmers, I hope we can pull it off. I would recommend that any team that has yet to decide should concentrate on having a consistent dumper rather than a shooter that might never work.
Unread 01-02-2012, 07:26
Da' Rule Man
AKA: Nik Shepherd
Can you really do that? I didn't think you could touch the fender. I thought it was a foul.
Unread 31-01-2012, 20:18
josephburns2487 josephburns2487 is offline
AKA: joe burns
FRC #2487
josephburns2487 is an unknown quantity at this point
The team I am mentoring is doing a shooter and I agree for this year’s game that it is a better idea. I think that it is just a better idea simply for the fact that you are protected when you shoot from the key, if you were not protected in the key this would be a whole different conversation in my opinion. and like said above it is getting a little late to be changing your mind on major design components.
