Go to Post This is one case where I really wish Andymark didn't listen to their customers so well. - ASD20 [more]
Unread 01-02-2012, 12:22
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Extrapolating Direction From Images
Has anyone gotten direction extrapolation working using the included VIs? We're trying to find a way to determine how far off center the camera is and have the base correct for it. I know that the processing software will vary the distance measured with respect to the angle of the camera, and with that measurement it's definitely possible to have the robot center itself using the ultrasonic sensor as a verification method, but I'm not sure how to determine which direction the robot has to turn in order to correct itself.
Any ideas?
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 01-02-2012, 12:37
Re: Extrapolating Direction From Images
In addition to the distance, the vision code you're working with tells you the location on the image of the target. Use the x coordinate of the target to decide which direction you need to turn the robot, and how far.
Unread 07-02-2012, 16:56
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
Excellent! We got basic auto-aim working, it may need a bit of tuning, but we'll need carpet and more weight on the robot to fully tweak everything.
http://youtu.be/HreYf3EIXPY
Unread 07-02-2012, 17:29
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
When you figure out the way to tune your auto-aim, do you think you could post it here? I think a lot of teams would appreciate it.
Unread 07-02-2012, 18:10
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
It really depends on how exactly you code the auto-aiming. If you use PID to get the target in the center of the camera's field of view, then it's really just a matter of tuning the PID parameters to get the best results from your system. There are many ways to tune a PID controller, but one of the most common (and easiest to implement in our timeframes) is a guess/check and Ziegler–Nichols combination. I'm not sure there's really much information to post.
But if you have specific questions about the logic/methodology behind auto-aiming, ask away, I'd be happy to answer.
Unread 09-02-2012, 21:19
VelocityofGear's Avatar
VelocityofGear VelocityofGear is offline
FRC #4347 (Mechanical End)
VelocityofGear is an unknown quantity at this point
Hello.
Attached is the portion of the code I am using to control a motor to align to a target. I am encountering problems in determining the logic to have the motor focus on the target chosen.
From the picture, I have taken the position of the x-value and specified when the value is less than 0.09 and greater than -0.09 to assign an output of 0, allowing the motor to stay fixed on the target. Yet when the values are out of this range, I'm looking for the motor to move clockwise or counter-clockwise to set its value within that range. I am having trouble using the x-position to center itself on the target.
We have read through the Vision Target processing and checked FRCMastery's section on vision processing; however, we are still having trouble.
Any pointers would be greatly appreciated. Thank you in advance for your responses and time.
Unread 09-02-2012, 22:24
plnyyanks's Avatar
AKA: Phil Lopreiato
Here are some pointers.
But all jokes aside, you're going to want to use a PID Controller in order to get your turret to aim. A PID controller is a feedback control mechanism, which, simply put, means that it will calculate the error between your desired value (the "setpoint") and the current value (the "process variable"). So, since you have real-life feedback (your camera) as well as a desired value, you can use a PID controller to "lock onto" the target.
In LV, there's a PID palate, and you place PID.vi onto your block diagram. You will want to wire the offset between the center (x) of the target and the center of the image (
offset = xCenter - (xResolution/2)
) as the process variable to the PID controller, and put the setpoint at 0 (you want the center of target to be exactly in the center of your image). You will have to make sure that the output ranges are scaled properly, and also that the input ranges are both scaled to the same units (you shouldn't have to do any scaling in this case - both are a pixel offset).
Then comes the hard part. You'll have to tune the parameters of the controller. There are three parameters: P (proportional), I (integral), and D (derivative). See the links in my last post for some common approaches and read through this section of the wikipedia page for how the gains work.
And if you can't get this to work, there is a simpler (but much less robust method). You could figure out the sign of the offset between target center and image center. This will tell you if your turret needs to move left or right to get centered. Then, you can either send a positive or negative value to your motor, depending on the direction and keep a constant value sending until the offset is within a threshold for the center, when you stop the motor. This is similar to the approach you started with.
I would recommend going with a PID solution because it's much more powerful and robust than the other way, but it does take some time and effort to get right. There are a lot of resources out on the internet and around ChiefDelphi for you to use. And as always, feel free to ask questions.
Unread 15-02-2012, 00:24
Very funny lol With all the reading and work getting done, it was nice to have a little humor.
I read through the documents, thanks for the links. However, I still do not understand how the process is accomplished inside of LabView. I set up a case select for the automation to run when a button is pressed down.
I think I set up the input and outputs for the PID block correctly as you stated. I enclosed a screen capture of what was done.
You mention to use this code:
I think that is what I have done, I still am unsure however.
As you can see from the picture, I manually set the pixel value for the camera in the x direction. Is there a better way of doing this? Maybe as a variable that will update if the settings are changed?
Last edited by VelocityofGear : 15-02-2012 at 00:26. Reason: Needed to attach picture
Unread 15-02-2012, 07:53
I think that if you look at the Rectangle processing, it has already defined the X and Y position to be in the range of -1 to 1 to be more like a joystick. Unless that code has been removed, subtracting 320/2 doesn't make sense.
Greg McKaskle
Unread 15-02-2012, 10:16
Greg McKaskle
Then what about comensating for the pixel offset as mentioned?
This post clearly states there must be an offset created and it makes sence. If there is no offset then how would the PID controller know the error and hence how to correct for it?
Unread 15-02-2012, 10:56
juchong's Avatar
Electrical Engineer
AKA: Juan Chong
From our testing, with the stock kitbot setup and using PWM, it's nearly impossible to have the robot precisely move to a certain position. The slop in the chain, transmission, and the varied power needed to overcome the moment of inertia are all contributing to the robot overshooting in order to attempt to aim.
Our solution: use CAN and encoders on the transmission, tune motor PID on the carpet, and tweak autoaim code. CAN enables us to closely monitor the number of rotations or set a speed at which to track, no matter what resistance the wheels meet (to an extent).
The overshoot that everyone is noticing with the example above is due to the camera being slightly off and the robot trying to precisely correct. This can be improved by using more case structures which vary the motors' power, instead of having a single power at which the robot will track, but it won't solve the problem.
