Go to Post Maybe Dave's just bananas for FVC? - Billfred [more]
Unread 03-02-2012, 11:17
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
CAN questions?
So i think we set up our can properly yesterday is their any way to find out if it works without a computer and program because we are waiting for our programming mentor to come.
Unread 03-02-2012, 11:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: CAN questions?
You need a computer running BDC-COMM to tell if the CAN network is set up correctly. In fact, you really need a computer running BDC-COMM to set up the network correctly in the first place.
Unread 03-02-2012, 11:37
Shaun Coon's Avatar
FRC #2487
Re: CAN questions?
ok?
Unread 03-02-2012, 11:51
Re: CAN questions?
BDC-COMM is a program you can run on a computer to set up and test your CAN Network. With it you can:
-Check network communications. It will give you a pull down list of all Jags on your network.
-Set CAN IDs. Each Jag needs a unique CAN ID.
-Test run a Jaguar. There's a diagnostic screen that gives you a readout of various values the Jag is seeing, and lets you manually give an output command to the Jaguar.
So you need that to give each Jag a CAN ID, and it's really useful to check out your network setup to make sure you can see all the Jaguars. Here's the BDC-COMM user guide.
