Motor/ Voltage Compensation
Does anybody have a way to compensate for when the voltage to a motor decreases so that we can keep the motor output constant?
Re: Motor/ Voltage Compensation
Are you trying to run the motor at a constant speed? You'll want to use a sensor so you can tell what the speed actually is and increase the power if it is too low.
We have a guide on closed loop control which you may find helpful:
http://team2168.org/index.php/resour...ntrol-tutorial |
