Go to Post Not everything has to be cashed in or has to have instant recognition. Sometimes being a part of a program of value and opportunity is enough. And, what you put into the program is what you get out of it. - JaneYoung [more]
Unread 06-02-2012, 14:13
Team4014 Team4014 is offline
FRC #4014
Team4014 is an unknown quantity at this point
Exclamation Watchdog Lag
Hello,
We have been having issues with the watchdog and our wireless connection since day 1. The watchdog keeps disrupting the wireless connection, saying "Watchdog not fed," and that makes the robot very delayed and quite dangerous to test on the ground. We're wondering if we're doing something wrong with the wireless router, and we also want to disable the UserWatchdog. Wired works fine, so we're stumped. Any help would be much appreciated. Thanks!
Unread 06-02-2012, 14:38
Re: Watchdog Lag
Do you have any way of sniffing for wireless networks in the area? Your DAP might be on a WiFi channel that's already in use nearby. If you can determine an open channel, or at least one that doesn't have a strong signal from some other access point, you can configure the DAP to use that channel.
Unread 06-02-2012, 14:45
kjohnson's Avatar
kjohnson kjohnson is offline
Insert Clever Title Here
AKA: Kyle J.
FRC #1610 (BOT)
kjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond reputekjohnson has a reputation beyond repute
Re: Watchdog Lag
To check for other networks, you can use InSSIDer. Its a great free tool from metageek that will show you the strength and channel of nearby networks.
