Go to Post If robotics is bad for you, well then I guess I'm gonna die. At least I'll die happy. - karinka13 [more]
Unread 06-02-2012, 20:08
Team4014 Team4014 is offline
FRC #4014
Team4014 is an unknown quantity at this point
Exclamation Bad Router
Hello again,
Whenever we hook the computer wirelessly or directly to the router we have MAJOR lag issues. The robot does things we don't tell it to do.....
But, whenever plugged into the cRIO, we have no issues.... The team feels that we have a bad router..... anyone else have this issue? If so, how did you get around it?
Thanks
FRC 2013 2nd-Year Team
Unread 06-02-2012, 21:52
EricH EricH is online now
Re: Bad Router
Check your channel use. Something else may be on the same channel. I don't know how to change the channel, though...
Unread 06-02-2012, 21:57
Garten Haeska's Avatar
Garten Haeska Garten Haeska is offline
AKA: Garty
FRC #2861 (Infinity's End)
Garten Haeska has a spectacular aura aboutGarten Haeska has a spectacular aura about
Re: Bad Router
We had this issue too... is your radio to close to your motors as in within a foot?
"Sometimes the questions are
complicated but the answers are simple."
- Dr. Seuss
Unread 06-02-2012, 22:05
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Bad Router
If you log onto the dlink (go to 10.te.am.1), you can click on "manually configure wireless settings" and select a different channel (or maybe auto channel scan?). That might fix it.... or it could just be the solar flares again, they caused us some intermittent problems recently...
Unread 06-02-2012, 22:45
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Re: Bad Router
We had a similar problem: see this thread for our solution.
Long story short, there was a 2 second lag between the driver station and robot access point.
So we upgraded the firmware (see above thread for link), eliminated conflicting devices (the root cause of the lag), and set/configured the dlink to bridge mode so that it connected to another router (don't know how much this helped though).
Good luck!
Unread 11-02-2012, 15:28
FRC #4014
Re: Bad Router
We had figured out that the router, when placed a distance away from the DC converter, would not drop out for more than a few milliseconds. I can assume those dropouts are simply bad packets, and the communication lag was caused by an interference from the DC converter.
