Go to Post We, as mentors, receive our greatest reward when our students become role models and give of their time to others in need. - Al Skierkiewicz [more]
Unread 07-02-2012, 15:13
tmccalister tmccalister is offline
FRC #2985
tmccalister is an unknown quantity at this point
Exclamation I cant deploy code onto my crio
Every time i do i get the SAME error. I need a simple explaination on how to fix this because my brain is dying.
Unread 07-02-2012, 15:14
FRC #2985
Re: I cant deploy code onto my crio
Waiting to connect to OTA command server of 10.29.85.2:8001 for past 698s
This is the error. How do i fix it?
Unread 07-02-2012, 21:46
Have you succesfully set the cRIO's IP address to 10.29.85.2 using the FRC 2012 cRIO Imaging Tool? Did you select the appropriate programming language and image version (v43)?
Is the cRIO reachable on the same network as your computer, and have you made sure there is no firewall or overzealous antivirus software active?
Unread 07-02-2012, 22:18
FRC #2985
I fixed all that. Now the error is actually this
DIO LoopTiming: 260, expecting: 261
How do i fix this? I can show you the entire build log if you need.
Unread 08-02-2012, 14:02
This is a known bug. See http://firstforge.wpi.edu/sf/go/artf1431
