Go to Post 1114 is the definition of what a FIRST team should be. For anyone to say otherwise is disgusting to me. - Andrew Schreiber [more]
Unread 07-02-2012, 18:39
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Compressor issues, and motor issues
Hey guys,
I've been trying to get this compressor to work for a while now and i had it working and its stopped again.
Its a bit strange, but the spike will go on/off pretty rapidly. I noticed that the fuse for the sidecar was not Plugged in, and when i plugged it in the compressor just went to a static light. I've enabled the compressor loop in periodic tasks, and just did "open - start - -->" in begin to start it. Any help is greatly appreciated.
Ive also been trying to make a motor controlled by the throttle on the joystick. Ive simply plugged the Axis 3 into the MotorSet vi (output) but it didnt work. Any suggestions?
Thanks very much
Unread 08-02-2012, 05:44
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Compressor issues, and motor issues
make sure that all of the RefNums are correct. Under periodic, compressor is called "The name". Also, under begin, do open->Start->set refnum
