[FTC]: coasting mode: save your gearboxes!
With a tip from this thread, I was able to get the motors to stop dynamic braking at speed=0 and instead coast. The motivation was that the hard braking was damaging the gearboxes in our motors.
The main idea is "don't use speed = 0." Setting the speed to 1 avoids the braking mode. But this only works if the current speed was > 0 (forward). If the current speed was < 0 (backward), setting speed to +1 caused braking to happen. In this case using -1 avoided braking mode. In other words, the value to use for "coast" depends on the current direction of the motor. Therefore this requires access to the current speed setting of the motor. I created a "speed-setting" function for each motor that remembers the speed it was set to: Code:
setLeftSpeed( speed ); Code:
motor[left] = speed; Code:
short leftSpeed = 0; // global
bool coastMode = true;
void
setLeftMotor( short speed )
// the motor controller will brake (short) the motor
// if the speed value is zero. But setting the motor to 1
// only makes it coast if the previous motor value was > 0.
// So we set it to -1 if the previous speed was < 0.
if ( speed == 0 && coastMode )
if ( leftSpeed < 0 )
speed = -1;
else
speed = +1;
leftSpeed = speed; // remember it
// globals:
short rightSpeed = 0;
void setLeftMotor( short speed );
void setRightMotor( short speed );
task main()
short speed = 75; // (could be changed using buttons or joystick.)
initializeRobot();
waitForStart(); // wait for start of tele-op phase. REQUIRED BY FIRST!
// let the driver press and hold RT to change from COAST to BRAKE mode.
if ( (joystick.joy1_Buttons & BTN_RT) )
coastMode = false; // brake
else
coastMode = true; // coast
// simple tophat drive: forward, backward, spin left, spin right:
switch( joystick.joy1_TopHat )
case 0: // forward
setLeftMotor ( speed );
setRightMotor( speed );
break;
case 4: // backward
setLeftMotor ( -speed );
setRightMotor( -speed );
break;
case 6: // spin left
setRightMotor( +speed );
break;
case 2: // spin right
setLeftMotor ( +speed );
break;
default: // stop
setLeftMotor ( 0 );
setRightMotor( 0 );
} // switch( joystick.joy1_TopHat )
void
speed = -1;
else
speed = +1;
void
// (see note about coasting in setLeftMotor()).
if ( rightSpeed < 0 )
speed = -1;
else
speed = +1;
rightSpeed = speed; // remember it.
motor[right] = speed;
Re: [FTC]: coasting mode: save your gearboxes!
RobotC has a function similar to this built in, but I think it only works with the three LEGO NXT motors.
http://www.education.rec.ri.cmu.edu/..._res_words.pdf bFloatDuringInactiveMotorPWM = true; (or false; ) This is used to set whether the motors on the NXT will float or brake when there is no power applied. There are two settings: false - motors will brake when inactive true - motors will float when inactive Thanks for posting code that provides the same functionality for the 12V DC motors! |
