Go to Post Winning medals and awards, being on TV or in a magazine while cool doesn’t even begin to compare to the relationships I’ve developed working with a bunch of great students. - ebarker [more]
Unread 09-02-2012, 03:29
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Signal Led
Our signal led light is not working.
its connected as written in the poer distribution digram.
we don't know what to do.
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 09-02-2012, 03:38
Cecil's Avatar
Cecil Cecil is online now
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: Signal Led
Have you done the DB37 rework as listed here?
If so, check your polarity on the light, try flipping the connector. The positive lead should go to the outside 2 ports on the light, and ground to the center port.
I'm right 90% of the time, so why worry about the other 3%?
Unread 09-02-2012, 07:49
Re: Signal Led
Yarden,
Try connecting the light directly to an unused output on the PD to see if it comes on. If the digital sidecar is feeding the signal light, there is an LED on the board next to the RSL white, two pin connector on the DSC. If that is not coming on, the RSL will not work. The LED is in parallel with the connector. It is also possible for a student to terminate the connector without actually having the wire electrically connected. If all else fails, on rare occasions, the LED may actually be defective.
Unread 09-02-2012, 11:07
Shaun Coon's Avatar
Shaun Coon Shaun Coon is offline
FRC #2487
Shaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the roughShaun Coon is a jewel in the rough
Re: Signal Led
you powered the sicard right?
Unread 09-02-2012, 11:09
Shaun Coon's Avatar
FRC #2487
Re: Signal Led
and for the light you connect the two outer ports together with a wire this is going to be positive and you connect the black - to the middle port
