Go to Post May we always remember those who have shaped our lives for through us they shape those around us. - mechanicalbrain [more]
Unread 09-02-2012, 15:26
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
robot drive isn't running fast enough...
we are getting an error that "the loop that contains robotdrive is not running fast enough." we program in labview and this error even occured when we made a fresh project with only the drive code we still get this error. could it be the two year old jaguars we are using?? plz help
Unread 09-02-2012, 16:02
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: robot drive isn't running fast enough...
The error messages you are seeing are not related to the actual 'speed' of your drive. They refer to how often new data is sent to the motor controllers.
This can be the result of running the robot on a congested network, clicking the run button rather than permanently deploying the code, or having time consuming loops in your teleop.
If you are developing on your driverstation computer, it can be a result of having 2 accounts running at the same time (driver station and developer), or having too many programs open.
Unread 16-02-2012, 19:20
Pirate programe's Avatar
Pirate programe Pirate programe is offline
FRC #0354
Pirate programe is an unknown quantity at this point
Loops? We don't have any loops in our teleop code, just case structures and select functions. But we still seem to be getting this error. Do case structures actually have the same overhead as a For/While loop, or what?
Unread 16-02-2012, 21:05
Neither case structures nor the loop have much overhead. But if you add code that delays teleop you will see this. If this happens using a loop, it isn't actually the loop that is the problem.
In this case, the issue is that the Mecanum is only called when button 1 is pressed. I can't see the code in the other case, but assume it is not calling the Mecanum Update. If you call teleop but it doesn't call Update for 100ms, that will still result in the safety mechanism halting the motors.
Greg McKaskle
Unread 16-02-2012, 21:42
CRLS97 CRLS97 is offline
FRC #0097
CRLS97 is an unknown quantity at this point
Greg McKaskle
Quick question when you say it doesn't update the Mecanum (for the code above)- just to clarify, you mean it has to update it in any way possible and it won't matter if in one case statement I have Arcade Drive and another Tank Drive? but they're still coming from the same Drive Ref.? As long as the Drive Ref gets some sort of update within every 100ms it's good, correct?
Unread 17-02-2012, 15:23
FRC #0354
I don't see any reason why that wouldn't be true, but keep in mind that updating the same drive train with two different VIs could possibly cause conflicts.
Unread 17-02-2012, 20:40
I'm pretty sure that is correct. The various drive options just do a bit of math and update the motor group. The RobotDrive refnum returned from the Open is the thing that has the timer associated with it. So, update the drive every 100ms or turn off the safety feature or you will receive a message and the robot motors will be zeroed in the timeout case.
Greg McKakle
