Jags will not calibrate
New weird issue...
Configuration: 4 black jags wired to CIM motors Running Mecanums on the Nanos (kinda rhymish )Using PWMs to Digital Sidecars Scenario: Tried to calibrate jags but two would not calibrate (on opposing corners of the bot). After multiple attempts to calibrate: Changed out PWMs for new ones....still didn't calibrate Then Changed out jags for two good ones that had been previously calibrated...still didn't calibrate Ideas? Would like to figure out the problem because it is kind of tweaking our drivers a little bit (I suggested changing the power wiring and have been told it is a 'non-factor' their latest new terminology...) |
Re: Jags will not calibrate
What exactly did you mean by "didn't calibrate"? For FRC, Jaguars' default factory calibration is acceptable for drivetrain use. |
Will try this next and let you know...
Last edited by rsegrest : 09-02-2012 at 19:39. Reason: re-read problem answer and realized I am a dufus... |
