Go to Post According to my father the hint should be released sometime next week, but he's never been the most trustworthy source of info.... - Lil' Lavery [more]
Unread 09-02-2012, 22:44
a240 a240 is offline
FRC #2713
a240 is on a distinguished road
Problems using CAN with PID
Hello,
I've been trying to use the CANJaguar class with PID control, but due to a lack of examples and documentation it has been a lot of guess and check work. I have successfully created a CANJaguar object and correctly configured it to the point where I could get encoder feed back. However I have run into a bit of trouble trying to use PID Control with the robot.
Here is some sample test code I created for a CANJaguar based driveTrain: http://code.google.com/p/iraiders-fr...riveTrain.java
My problem is that even after setting a setpoint value using setX(x), the driveTrain wheel fail to move. Testing shows that the method getX() returns a value of zero. What's wrong? If anyone knows anything about the topic any information would be very helpful.
Unread 09-02-2012, 23:34
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: Problems using CAN with PID
Try with kSpeed instead of kPosition for ControlMode. Unit is Rotations/Minute.
You can also use bdc-comm to adjust the CAN jaguars directly through serial cable.
Unread 10-02-2012, 17:26
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Agreed you must switch to kSpeed. You will need different P I D numbers when you switch to kSpeed. For tuning speed mode, start with the I number (not P as you would for kPosition). Once you have an I you like, you can ramp up P to tame minor oscillations. Always set D to zero in speed mode. There are several posts which give more details on tuning CANJaguar kSpeed controllers.
Unread 10-02-2012, 20:30
Programming
Wait a second. Why does D have to be set to 0 in speed mode? Ours seem to work best with P=.700, I=.085, D=5.000
Unread 11-02-2012, 20:25
LukeS LukeS is offline
4272 mentor, 1024 alumnus
AKA: Luke Shumaker
FRC #4272
LukeS is an unknown quantity at this point
It varies, there are different strategies. This year I've had good luck with speed control using the Ziegler-Nichols method (search it) with P and I (no D).
