Go to Post Andy Baker can legally touch the Red and Blue Carpet simultaneously. - Taylor [more]
Unread 13-02-2012, 01:19
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
pic: MARS 1523 Finished Robot
Unread 13-02-2012, 01:20
Re: pic: MARS 1523 Finished Robot
Not sure if you're finished just yet...that concave front looks pretty illegal.
Unread 13-02-2012, 01:37
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
yep, what he said.
2016 Central Illinois Winner. Curie Division finalist
Unread 13-02-2012, 04:25
codes02 codes02 is offline
Randolph aka Roxbury aka R_______
AKA: Cody Schafer
no team (Formerly: Team 11, MORT)
codes02 is on a distinguished road
Can one of you cite the rule which you think makes the concave front an issue?
Unread 13-02-2012, 04:50
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
im guessing the bumper rule
Unread 13-02-2012, 05:00
AKA: Cody Schafer
So long as bumpers are used to cover 8 inches on each side of each corner, there doesn't appear to be any issue with the bumper rules.
The bumper rules don't have any restriction on the angles at which the bumpers (or the sides of the robot) meet.
Unread 13-02-2012, 06:36
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
[R01-2]
The Robot must have a Frame Perimeter that is comprised of fixed, non-articulated structural elements of the Robot. The Frame Perimeter of a Robot is defined by the outer-most set of exterior vertices on the Robot that are within the Bumper Zone, which is between 2 and 10 in. from the floor. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the Frame Perimeter.
To determine the Frame Perimeter, wrap a piece of string around the Robot at the level described in [R02]. The string describes this polygon.
Note: to permit a simplified definition of the Frame Perimeter and encourage a tight, robust connection between the Bumpers and the Frame Perimeter, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the Frame Perimeter.
The carpet, the Bridge surfaces, and Keys are considered the flat floors – and thus are the reference planes for the Bumper Zone requirements. A Robot in a transitory state of crossing onto/off of a Bridge or Barrier is not considered to be on a flat floor.
So if you put that string around you robot, that is where you bumpers must be. Your setup is illegal.
Unread 13-02-2012, 07:57
45Auto's Avatar
45Auto 45Auto is offline
FRC #2992
45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future45Auto has a brilliant future
To elaborate on IndySam's post:
The string will define your frame perimeter.
Rule R27 says:
[R27]
Robots are required to use Bumpers to protect all exterior vertices of the Frame Perimeter. For adequate protection, at least 8 in. of Bumper must be placed on each side of each exterior vertex (see Figure 4‑1, Figure 4‑2, and Figure 4‑3).
Therefore you need at least 8 inches of bumper on each side of the front corners of your robot, right?
Rule R33 says:
[R33]
Bumpers must be supported by the structure/frame of the Robot (i.e. each end of the Bumper must be rigidly attached to the Frame Perimeter, the gap between the backing material and the frame must not be greater than ¼ in. and no section of Bumper greater than 8 in. may be unsupported). See Figure 4‑7.
Those concave front members ARE NOT part of your frame perimeter (frame perimeter is defined by the string, remember?)
How are you going to attach 8 inches of bumper to the front of your robot and have it rigidly attached to the frame perimeter?
The rules have pretty well ruled out robots with a concave front.
2007 - Rookie All Star - Bayou Regional (1858 - Tyborgs)
2009 - Rookie All Star - Bayou Regional (2992 -Prometheus)
2010 - Champions - Bayou Regional (2992 -Prometheus)
2012 - Finalist - Bayou Regional (2992 - Prometheus)
team2992.com/design.php
Unread 13-02-2012, 14:19
gman892's Avatar
gman892 gman892 is offline
#2785
FRC #2785
gman892 is an unknown quantity at this point
Where is the circuitry?
