Go to Post anything that craves Mountain Dew is definitely intelligent enough to be dangerous. - IMDWalrus [more]
Unread 13-02-2012, 17:03
ablahblah ablahblah is offline
The Blaghh!
AKA: Alex
FRC #4404 (The Nuts 'N Colts)
ablahblah is an unknown quantity at this point
Merging strings in LabView
I'm trying to get the User Messages panel on the Driver Station to work, but i'm not sure of what VI i should be using to merge strings. I need to merge two text strings around a decimal input coming from a motor (I think the number to decimal string vi is what i need to be using), and I'm currently trying the concatentate strings vi. It just draws a blank after the first string though.
Unread 14-02-2012, 10:52
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
Re: Merging strings in LabView
You could try something like this using the Format Into String function.
Name:	format into string.jpg
Doug Norman
