Go to Post I have always been of the opinion that if the mechanicals are making noise they are trying to talk to you. - Al Skierkiewicz [more]
Unread 14-02-2012, 20:42
team4213 team4213 is offline
FRC #4213
team4213 is an unknown quantity at this point
GPIO Tolerance
What are the tolerances for input voltages for the signal pin of the GPIOs? In other words, at what point does the GPIO switch from reporting true (high) to false (low)? Does the signal pin have to be taken to 0 volts (i.e directly connected to ground) or is there some point where a low enough voltage will be considered low (and thus report false)?
Unread 14-02-2012, 20:48
therealman1's Avatar
therealman1 therealman1 is offline
FRC #3044
therealman1 can only hope to improve
Re: GPIO Tolerance
if you are useing java you can print the output of it to the drive station, then through testing it you can get a ball park estement
Unread 14-02-2012, 21:12
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: GPIO Tolerance
From the datasheet for the DIO module at National Instruments
The module can take inputs with a voltage of –0.25 to 5.25 V
When the voltage exceeds 2.2 V, it is 'high'
High, VIH 2.2 V min
When the voltage falls below 0.8 V, it is a 'low'
Low, VIL 0.8 V max
Anything in-between is no-mans lands.
Ed Barker
Unread 15-02-2012, 19:18
FRC #4213
Re: GPIO Tolerance
Exactly what we needed to know. Thanks!
