Go to Post No amount of sleep beforehand will make up or prepare you for the lack of sleep you will receive during build season. - Dan Petrovic [more]
Unread 15-02-2012, 16:22
nighterfighter nighterfighter is online now
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
CANJaguar and Encoders
How do I set a Jaguar, using CAN, to read the encoders and to rotate to a certain position?
I'm assuming I can set the ControlMode to PositionControl, but after that I am not sure what to do.
Unread 15-02-2012, 17:08
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: CANJaguar and Encoders
set the control mode:
void ChangeControlMode(ControlMode controlMode);
set the gains:
void SetPID(double p, double i, double d);
set the position feedback device to encoder:
void SetPositionReference(PositionReference reference);
enable control:
void EnableControl(double encoderInitialPosition = 0.0);
set a reference:
virtual void Set(float value, UINT8 syncGroup=0);
Unread 15-02-2012, 17:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You also need to SetPositionReference, SetPID, and ConfigEncoderCodesPerRev.
Once you do all that, you EnableControl, and then Set the position you want.
The trickiest part is setting the PID values to useful numbers. You'll need to experiment here, and you'll want to start with small number and work your way up. Sadly, you HAVE to do this with your system completely together. You can't tune a PID unloaded and then add a load and expect it to work well or at all.
