Go to Post Maybe LabView needs to have a watchdog for goofy programmers... - johncap100 [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 16-02-2012, 15:18
ballsohad777 ballsohad777 is offline
FRC #2554
ballsohad777 is an unknown quantity at this point
No COM error
It seems like I wired everything correctly. I tested out each individual wire from every phone wire and they all work. I also have 2 resistors- one on the last jaguar in the can series and one on the wire connecting the db9 to rj12 cable (does it matter which side it is on?). I try to run the program, but once it is opened up, the program says "No COM port.." and doesn't allow me to continue. What's wrong?
Unread 16-02-2012, 17:13
Re: No COM error
Assuming that "the program" is BDC-COMM, it's saying it can't find a serial port on your computer. It has nothing to do with your wiring.
Do you have a serial port built into your computer? Are you using a usb-serial converter? Does the windows device manager recognize your serial port?
Unread 17-02-2012, 15:33
Efiske Efiske is offline
FRC #2367
Efiske is an unknown quantity at this point
Re: No COM error
The Classmate laptop doesn't have a Serial port (I learned the hard way that I was mixing up Ethernet ports and Serial ports ) so you'll have to use a computer that does. Be sure to use the latest version of BDC-COMM, v101, over here: www.ti.com/jaguar on the right hand sidebar of the page.
Unread 17-02-2012, 19:46
FRC #2554
Re: No COM error
I got the program to not say no com ports, but now there is a new problem. It says that it can't locate the specified com port. I think it may be a serial port problem like you guys said so I'm trying to find one, but I don't know which one to download on the internet. any suggestions?
Unread 18-02-2012, 00:41
Re: No COM error
You can't "download" a serial port. It's a hardware connection. If your computer doesn't have one built in, you'll have to physically install one. A desktop system might be able to accept a plug-in card, but one typically uses a USB-to-serial adapter cable.
Such an adapter was available through FIRST Choice this year.
