Go to Post The next hint will be game hint #3. Everyone will go crazy trying to figure out which of the fake hints was hint #2. - Joe Ross [more]
Unread 17-02-2012, 22:15
mr_yes mr_yes is offline
FRC #1248 (The TITANium Allies)
mr_yes has a spectacular aura aboutmr_yes has a spectacular aura about
Wiring the GTS from the 2008 KoP
We are planning on using the Gear Tooth Sensors from the 2008 KoP with this year's robot. The sensor uses both a Digital I/O connector to connect to DIO on the sidecar, but it also requires a 12V power supply. Where should this 12V supply be connected?
Unread 18-02-2012, 01:10
Re: Wiring the GTS from the 2008 KoP
It should be powered by a 20 Amp branch circuit from the Power Distribution Board.
Unread 18-02-2012, 15:33
Okay, that's about the only place I could think of where we could legally get 12V, but it seemed like serious overkill. Thanks for the confirmation!
