Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 17-02-2012, 22:15
GreenRock GreenRock is offline
FRC #4378
GreenRock is an unknown quantity at this point
Pit station at competition
How will power be supplied? Does everyone need to bring a generator or will there be outlets for all of our tools?
Unread 17-02-2012, 22:18
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Pit station at competition
Power is supplied to each pit. It may vary by competition, but not by much since FIRST sets standards for what and how it is supplied.
You can expect a power drop into your pit that you can plug into.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-02-2012, 22:20
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
*pictures 50 or so generators humming away in the pits*
Unread 17-02-2012, 22:28
FRC #4378
Thank you! My team has no means of buying an expensive generator. Glad to know power is going to be supplied.
Unread 17-02-2012, 22:37
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Expect your team to have 2 outlets available at the worst possible part of you pit you can think of.
Bring a couple shortish extension cords(your pit is only 10x10) and a power strip or two.
KK4KQO
http://voltair.us
Unread 19-02-2012, 22:05
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Well, can you imagine 50 generators running in a closed building? Can you say illegal. In all fairness everybody has to use some common sense here. Even here at the Suffield Shakedown Scrimmage in Connecticut we provide power to every team. Don't worry, you won't have to worry about power. All regional events also supply some type of machine shop and advice from officials & other teams. Don't be afraid to ask for help. It will be there.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
