Go to Post Why not go the safer route? Use the robots to play Magic the Gathering. - kamocat [more]
Unread 20-02-2012, 11:30
DBortnick's Avatar
DBortnick DBortnick is offline
AKA: Daniel
FRC #1850 (Mechanicats)
DBortnick is on a distinguished road
There is a problem with my code please help
#include "WPILib.h"
#include "Commands/Command.h"
#include "CommandBase.h"
#include "Logger.h"
class CommandBasedRobot : public IterativeRobot {
private:
// Command *autonomousCommand;
Logger *logger;
virtual void RobotInit() {
Logger::GetInstance();
CommandBase::init();
// autonomousCommand = new DriveWithJoystick();
virtual void AutonomousInit() {
// autonomousCommand->Start();
virtual void AutonomousPeriodic() {
// Scheduler::GetInstance()->Run();
virtual void TeleopInit() {
// This makes sure that the autonomous stops running when
// teleop starts running. If you want the autonomous to
// continue until interrupted by another command, remove
// this line or comment it out.
// autonomousCommand->Cancel();
virtual void TeleopPeriodic() {
logger->Log(Logger::kINFO, "In TeleopPeriodic()");
logger->Log(Logger::kINFO, "Starting Sweeper");
CommandBase::sweeper->run();
logger->Log(Logger::kINFO, "Starting Conveyor");
CommandBase::conveyor->run();
CommandBase::drive->driveWithJoystick(CommandBase:i->getLeftJoystick());
START_ROBOT_CLASS(CommandBasedRobot);
The issue is that one wheel works which is the left wheel. I cant get the sweeper to work or the other wheels
Coach for Team 1850
ACE Technical Mechanicats - Chicago, IL
http://www.facebook.com/Team1850
Unread 20-02-2012, 11:36
DBortnick's Avatar
AKA: Daniel
Re: There is a problem with my code please help
Im also getting a error the I/o unity not detected or not installed correctly
Coach for Team 1850
Unread 20-02-2012, 11:41
Dusk Star's Avatar
Dusk Star Dusk Star is offline
team Chief Delphi junkie
AKA: Andrew
FRC #2611 (Jacktown Vectors)
Dusk Star is an unknown quantity at this point
Check that your digital breakout board has power- there should be three green lights on it. Does your robot signaling light work? (or whatever it's called, the big orange light)
Unread 20-02-2012, 11:46
DBortnick's Avatar
AKA: Daniel
Okay that all works
Coach for Team 1850
Unread 20-02-2012, 11:51
Dusk Star's Avatar
AKA: Andrew
Well, I have no idea. good luck, and remember that code does not ship with the robot!
Unread 20-02-2012, 15:23
You didn't post anywhere near enough code for us to help you figure out what's wrong.
The "I/O unit" message is just informing you that the Driver Station didn't detect a Cypress PsoC connected via USB. If you're not intending to use one, you don't need to worry about the message.
