Go to Post Smokey the Fisher Price motor says only YOU can prevent rule infractions. - artdutra04 [more]
Unread 20-02-2012, 13:26
Arrex's Avatar
Arrex Arrex is offline
FRC #4296
Arrex is an unknown quantity at this point
Driver control panel
I've been charged with constructing my team's control panel to contain the computer and joysticks, and I'm wondering if there are any major dimension constraints. I've heard that it cannot be more than 1' long in a certain direction, but I have been unable to find such a rule.
I currently have a 20x30x3 5/8" wood box built. I can cut it down if necessary.
Unread 20-02-2012, 13:32
Re: Driver control panel
[R82] says that you're OK on the length, but you're going to have to cut the 20" down to 12".
[R82]
The Operator Console must not exceed 44 in. long by 12 in. deep (excluding any items that are held or worn by the Drivers during the Match).
Unread 20-02-2012, 15:06
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
I have seen operator consoles that are deeper than the shelf is (12"), and no one has seemed to mind, granted 20" is a bit much. There is velcro on the shelves, so putting the "hook" side on the bottom of your operator console is worth your while, especially if the whole box is SLIGHTLY deeper than the shelf.
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 20-02-2012, 15:59
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
^Ditto on the Velcro. I've seen entire control boards fall off the shelf during matches.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
