Go to Post Any adult can open a door. Some can give direction. A few can give leadership. These are the true mentors. This is where true success comes from. - sanddrag [more]
Unread 20-02-2012, 15:22
techno4229 techno4229 is offline
AKA: marcus
FRC #4170
techno4229 is an unknown quantity at this point
Lightbulb Robot main motor control
ok what im trying to do is have a button not just control the motor speed but when im moving around with (x,y) i wanna to be able to push a button to slow motor but still use (x,y) to move then when i release it, it goes to normal speed possible?
Unread 20-02-2012, 15:33
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Re: Robot main motor control
here you go. you can change the .5 to whatever you want. the false of this is just wiring the axis directly to the terminal
Unread 20-02-2012, 18:59
AKA: marcus
FRC #4170
thnx worked perfect... possible i can have it reverse? so its slow to .5 speed then when button to 1.0 ?
Unread 20-02-2012, 19:50
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Yes, just reverse your cases. Make your "True" case read "False" and vice-versa.
